F5 Turbo Builders Thread
Old 11th January 2013, 10:53 PM   #1041
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by AudioSan View Post
100W class A at 8ohm is a bias of 2.5A and about +/-45V rails.
45*2.5*2=225W (this is for 1 channel only ofcourse)
dont you divide by 1.3 for RMS .... ? interesting everyone has a different method or answer vs Rail voltage
Old 11th January 2013, 11:00 PM   #1042
AudioSan is offline AudioSan  Norway
this is calculation for dissipation. rail voltage*bias*2. or rail voltage*2*bias.
Old 11th January 2013, 11:02 PM   #1043
noSmoking is offline noSmoking  United States
noSmoking's Avatar
Howdy,
I set my V2 up with no sinks on the diodes,and adjusted the bias around and kept some fingers on the diodes,I set them to around 350 and then cranked the volume and that's when they come on ,I didn't let them stay on too long but a small heatsink should work,I think I will use a heatsink long enought for 2 diodes, maybe keep them closer heat tracking wise.
I read papa's article on them he said they work on the peak times of conducting to keep the impeadance low at high current draw ,if I got that right,LOL.
Thanks for the reply Buzz!
NS
Old 12th January 2013, 10:22 AM   #1044
Marra is offline Marra  United Kingdom
Thermoswitch from Farnell.
2455R-100-74 - HONEYWELL S&C - THERMAL SWITCH, NC, 70°C, 55°C | Farnell United Kingdom
Old 12th January 2013, 10:33 AM   #1045
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Originally Posted by noSmoking View Post
Howdy,
NS
They dont com eon suddenly, as they are sharong current with the resistors that they are in parallele dwith. As the current increases through that junction the Vdrop increases in proportion to the ratio of their resistance to the Rs. I am not sure they ever complete bypass the Rs, as this would cause instability in the output, moat likely leadin gto thermal runway. I woul dimagine, they work to maintain a similar Vdrop across Rs, regardless of current passing through the junction. Imagine Vdrop staying in the .4-.6V range instead of steadily climbing with increased current. This would affect degeneration amount, bias point, and gain, all in one. Sliding bias
...Shape the sound , Man!
Old 12th January 2013, 12:03 PM   #1046
noSmoking's Avatar
Thanks buzz I'll go back and read that article again,
NS
Old 12th January 2013, 04:04 PM   #1047
dazed2 is offline dazed2  Canada
I thought that people were having trouble even having the diodes turning on? ie , the circuit never gets driven hard enough to reach those V and current levels.
In the V3 with 4 pr is it then necessary to put heatsinks on the diodes?
Old 12th January 2013, 04:10 PM   #1048
buzzforb's Avatar
You want some sort of heat dissipation on the diodes no matter what. You have t consider there ability to get rid of heat. With out any thermal coupling. Their internal temp would vary greatly and make for an unstable amp. As a point in fact, in the Paradise bilders thread, there have been people who have been able to affect bias by simply blowing across the boards. Temperature is a major part of any amp build.It is exponentially more important in CLass A. If you want them to cut on, bolt them to the main sink. For most speakers, V3 without diodes may be sufficient, but it nce to have them.
Old 12th January 2013, 06:16 PM   #1049
Sin Bin
In my case yes, an 8 ohm load ..? i would still sink them , over building is always fun , lets you concentrate on the music...
Old 13th January 2013, 01:45 AM   #1050
nrg2009 is offline nrg2009  United States
So maybe it does make sense to mount the diodes on the main sink to warm them up and get them conducting at a lower voltage? It will also eliminate any concern of them overheating (under load).
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
