F5 Turbo Builders Thread - Page 102 - diyAudio
Old 11th January 2013, 01:03 AM   #1011
aha that will do the job right now i only got standar wirewound 5W. but i do want to get some mills at least R7-R10(feedback resistors)
all others are dale CFM60. exept R2. (i forgot to order it) so i used what i had. it will not make much difference after all
Old 11th January 2013, 01:13 AM   #1012
buzzforb's Avatar
Definitely at point of tweaking.
...Shape the sound , Man!
Old 11th January 2013, 01:19 AM   #1013
BigE is offline BigE  Canada
BigE's Avatar
Three chassis stereo amps make for expensive umbilical cords and a whole row of amp cases.
If effy is 25%, then a 100 watt class A amp will dissipate 400 watts at idle. One measure of xformer size is 3-5 times dissipation, so 1.6Kva will only be good for one channel anyway. Then two boxes is a must, or you can't lift it anyway.
This is going to be expensive.
Old 11th January 2013, 01:22 AM   #1014
2-3 times dissipation is good. so 600+VA pr ch of v3. i'll use 1000VA pr channel. but only becouse i allready got them
and a 100W F5 will consume about 250W
Old 11th January 2013, 01:22 AM   #1015
yes. i have to leave something for tweeking
Old 11th January 2013, 01:26 AM   #1016
buzzforb's Avatar
Don't get mad at me If you notice a difference. This weekend, Salaa RIAA with SMD.
Old 11th January 2013, 01:31 AM   #1017
Old 11th January 2013, 01:34 AM   #1018
a.wayne is offline a.wayne  United States
Sin Bin
100W class-a =400watts consumption ...
Old 11th January 2013, 01:40 AM   #1019
there is nothing to back up that
F5 at 100W @8ohm= 40V swing at the output. you will get that easely with +/-45V rails.
and 2.5A bias = 100W class A. (2.5*2)*(2.5*2)*8/2=100W.
45V*2.5A *2 = 225W dissipation pr channel
Old 11th January 2013, 02:10 AM   #1020
BigE's Avatar
Then what's all this about efficiency of class A being 25%? This amp is about 100/225! or 44%
So 1.6KVa is just fine for a stereo amp -- tall but still just one box. The problem with the height is: How do you bias it?
F5 Turbo Circuit Boards chchyong89 Pass Labs 2396 15th February 2017 03:10 AM
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 07:26 AM
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 11:05 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Copyright ©1999-2017 diyAudio
