Bosoz omit P1/P2
I would like to eliminate the potenziometris P1 and P2 from the bosoz and to simply maintain P3 and P4.
To do this I would set to the place of every pots a resistance from 10K as in the attached scheme.
according to you can it work ?
D.N.
Something you might want to consider is a fixed value of attenuation at the input. Granted that would work best if you only have one source going to the BoSoZ. But you could keep the circuit running in its sweet spot and adjust the volume at the output like you are planning.
