F5 Turbo Circuit Boards
Old 2nd March 2012, 05:34 PM   #881
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
High power class A?
Multiamping is your best friend.
No more need to build monsters.
(Class D for the bottom.)
Old 2nd March 2012, 08:43 PM   #882
Geofd is offline Geofd  United Kingdom
For me I want to build a V3 100W class A exactly as per the published design- to understand what kind of case/heatsink is needed a good refernce would be the musical fidelity AMS 100 - though this is balanced and bridged design (class A 100W into 8 ohm and 200W into 4Ohm)- it weighs in at 100Kg I recall
so all these cases/heatsinks discussed so far I expect will be far to small for a stero amp.
The plan is to use the Fischer SK535 (500 long * 400mm high) 0.08 K/W
SK 530 ... <br>SK 531 ... <br>SK 533 ... <br>SK 535 ... <br>SK 536 ... <br>SK 537 ... <br>SK 538 ... <br>SK 539 ... <br>SK 540 ..., Standardstrangkhlkrper, Khlkrper f.cool, Fischer Elektronik
So with 240 watts of dissipation then I hope to get around 20 degrees of rise.
And use the type of construction as per the recent absolutly amazing (or Fugly as some say) F4 posted in the Amp secton of this forum (bolt the top, bottom front ad back panels to the heatsinks)
I live in switzerland and to get these things made here will be quite expensive so maybe it will be cheaper just to by the 16k Euro AMS than build a case for the F5T ? lets see.
Old 2nd March 2012, 08:46 PM   #883
6L6 is offline 6L6  United States
6L6's Avatar
It will be significantly cheaper to do it yourself. The cases will be expensive, no doubt, but much cheaper than a commercial product.
Old 3rd March 2012, 12:17 AM   #884
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by JBL4435 View Post
Good joke
Dissipation is 260W per channel and I measure app. 45°C.
Don't know how you claculate but these mono chassis (4 of these heatsinks) have 0.07 K/W
From past experience they looked small for a 200 watt/ch Class-a amp ...
Originally Posted by AndrewT View Post
What's wrong with 150W of ClassA into 8r0?
That just 6.13Apk into the load.
And from a Push Pull amplifier like the F5, would require a bias of ~3.1Adc
The F5T would be equivalent to 75W into 4r0 from each half of the balanced amplifier.
Still a lot of heat and consumption .....
Old 3rd March 2012, 03:49 AM   #885
lhquam is offline lhquam  United States
Originally Posted by labjr View Post
I had considered having an enclosure made in the U S. However, it is quite a project to take on and there wasn't much interest last year. Everyone seemed to want the cheapest thing that would work. Personally, I like elegant stuff and it would be in my living-room so I don't have a problem if it costs a bit more than the cheapo offerings.
Would be even more difficult to do something for the F5-T since there are so many variations of the amp with different heatsinking requirements. So there proably won't be a one-size-fits-all enclosure.
Reading some of these posts, I think some maybe taking on a rather difficult project with V3 versions etc. I know, as I read the manual, I started to wonder if I really need more power than the original F5's 25 watts.
For most home audio situations I suspect that you are correct about 25 watts being enough. I am a firm believer in the FirstWatt principles.
Old 3rd March 2012, 07:09 AM   #886
Bksabath is offline Bksabath  United Kingdom
Banned
Maybe this help
http://www.diyaudio.com/forums/multi...kers-need.html
Old 3rd March 2012, 09:44 AM   #887
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by Geofd View Post
AMS 100 weighs in at 100Kg.
The MF has CLC power supplies, the 2 toroidal transformers and 4 block chokes (EI look) account for most of the weight.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 3rd March 2012, 12:19 PM   #888
labjr is offline labjr  United States
Is anything gained by adding diodes to the F5 output stage?
Old 3rd March 2012, 12:21 PM   #889
Banned
Unlimited by source resistors current
Old 3rd March 2012, 12:52 PM   #890
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
I still have a hard time understanding the operation that allows it to move from idle current over the source resistors to the diodes themselves. Is this determined by the diode behavior and characteristics?
Can someone spell this out for me using simple words, and easy math?
Some Salas Boards In stock, PM | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards PM for sign up | Sony VFET CSX2 AL boards Shipped | Vishay/Harris MOSFETs Click Here to Sign Up!
F5 Turbo Circuit BoardsHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
