F5 Turbo Circuit Boards
Old 27th February 2012, 07:43 PM   #761
Horio is offline Horio  United States
Horio's Avatar
I was kind of hoping you might make one of these.
Old 27th February 2012, 07:55 PM   #762
UKToecutter is offline UKToecutter  United Kingdom
Hey Horio
I thought you were going to make a V2?
Old 27th February 2012, 07:59 PM   #763
Horio's Avatar
I wasn't planning on it. I've been thinking of a pair of balanced V3 mono-blocks since early on.
Old 27th February 2012, 08:11 PM   #764
Originally Posted by lhquam View Post
The F5 is relatively insensitive to ripple on the rails, as long as it is the same on the rail ends of the MOSFET source resistor (R18) and the JFET drain resistor (R5). This is why case must be taken to minimize AC currents in the path between the rails on output board and the input board. You might allow for caps on both boards and people can experiment to see what works best.
Ihquam
I've added capacitor positions on the output boards.
Andy
Old 27th February 2012, 08:18 PM   #765
a.wayne is offline a.wayne  United States
Sin Bin
So whats the advantage if only running balanced inputs with SE outputs....
Old 27th February 2012, 08:28 PM   #766
oiphy is offline oiphy  Norway
diy newbie
oiphy's Avatar
easy upgrad rest of gear
" If you're going throu hell, keep going"
Old 27th February 2012, 09:18 PM   #767
lhquam is offline lhquam  United States
Originally Posted by UKToecutter View Post
Gentlemen,
I present the V3 Balanced input stage board.
I'm sure I can get it a bit smaller. It's currently 120mm x 64mm so smaller than 2 x SE Input stage boards.
Andy
The trace for the balanced connection R3, R4, P3, r29, R20, P6 also needs a terminal post or solder pad for grounding to disable the balanced mode and run each side independently. This is also needed for initial adjustment to set the bias currents, output offset, and 2nd harmonic. I would vote spst switch.
Old 27th February 2012, 09:19 PM   #768
chalkandtalk is offline chalkandtalk  United Kingdom
Thanks for the balanced board Andy.
I now need to work out how many output boards, voltages and bias to get 100W.
Old 27th February 2012, 09:19 PM   #769
Ihquam
I hadn't planned on people using this board for SE.
There is already a board for that
Old 27th February 2012, 09:26 PM   #770
MASantos is offline MASantos  Portugal
Ihquam
Will the board allow SE input without this?
F5 Turbo Circuit BoardsHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
