F5 Turbo Circuit Boards
Old 26th February 2012, 07:21 PM   #731
lhquam is offline lhquam  United States
UKToecutter:
I have some concerns about noise in the multi-board F5 Turbo. The (potential) problem is the the output boards have a voltage gain of between 8 and 16 into a 4 ohm load. The Turbo kicks in, the gain gets even higher. The voltage gain is calculated as follows:
Vgain = Rload * N-fets * 1/(Rsource + 1/Gm)
where Rsource = .5 ohm, Gm approx 2S.
The problem is that any voltage difference between the power rails of the output boards and the input boards due to noise will be amplified by the output stage. The Burning Amp v2.0 doesn't have voltage gain, since the MOSFET outputs are voltage followers.
This means that extra care is required to avoid AC voltage drops. The power rail wiring must be done carefully. Capacitors C2 and C2 probably should be eliminated or on the output boards rather than the input board to eliminate ripple and noise currents running through the rail wiring to the input boards. I suggest something like the following sketch:
Old 26th February 2012, 07:24 PM   #732
Originally Posted by labjr View Post
How about use the dual rectifier and a transformer with a couple more volts?
Should be fine. You should only need about 1 volt extra.
Old 26th February 2012, 08:26 PM   #733
6L6 is offline 6L6  United States
6L6's Avatar
Originally Posted by MASantos View Post
Regarding using fans, would it be for extra ventilation for the inside of the enclosure or directly on the heatsinks?
That would be completely dependent on your heatsinks. If they are undersized, (or made for forced cooling) they will need a fan.
Old 26th February 2012, 09:12 PM   #734
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
[QUOTE=lhquam:
... have a voltage gain of between 8 and 16 into a 4 ohm load. The Turbo kicks in, the gain gets even higher.
:[/QUOTE]
As voltage gain increases when turbo kicks in due to appearent diminushing Rs isn't that producing some kind of expansion of the dynamic?
Old 26th February 2012, 09:33 PM   #735
No, the feedback loop takes care of that. With turbo "kicked-in" the open-loop gain increases, and hence the amount of negative feedback also increases.
Old 26th February 2012, 09:43 PM   #736
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
you'll hear the CLUNK!
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 26th February 2012, 11:34 PM   #737
UKToecutter is offline UKToecutter  United Kingdom
Originally Posted by lhquam View Post
UKToecutter:
Yes,
I see your point, however, I would also imagine that any ripple would be a greater problem on the input stage.
It's not a big deal to add some cap positions on the ouput boards although it will mean running a ground connection that wasn't previously required.
Old 26th February 2012, 11:50 PM   #738
gaborbela is offline gaborbela  Canada
Hello UKToecutter
Would you please be so kind put me to the list for a stereo V3 set with one PS board.
I did tried but I couldn't do.
Greetings Gabor
Old 27th February 2012, 12:31 AM   #739
UKToecutter:
Yes,
Old 27th February 2012, 12:34 AM   #740
Originally Posted by gaborbela View Post
Hello UKToecutter
Greetings Gabor
Gabor
for a stereo V3 you'll need 2 input boards, 4 output boards and 2 PSU's
F5 Turbo Circuit BoardsHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
