F5 Turbo Circuit Boards - Page 71 - diyAudio
Old 26th February 2012, 12:32 AM   #701
nrg2009 is offline nrg2009  United States
Does anyone have a rough estimate about heatsink size requirement for the V2 combo board? I was looking for a GB for sinks..
Old 26th February 2012, 01:30 AM   #702
lhquam is offline lhquam  United States
The size depends on whether you are willing to use a quiet fan or just use natural convection. With a fan you get 3x-4x smaller heatsink.
Old 26th February 2012, 02:14 AM   #703
koja is offline koja  Canada
i already let Andy know but for the record:
For me please:
2 input stage boards (70x70mm)
8 single fet output boards (35x50mm),
and please try to make the dimensions stick. no more changes pls Thx.
Now, if you guys would get past sharing your heatsink designs (everybody's different, Ok, so no details pls..):
Is there some interest maybe in discussing getting matched fets? at least P-to-P and N-to-N matched and then P-to-N side will be left to the trimmer?
Old 26th February 2012, 03:25 AM   #704
sangram is offline sangram  India
Originally Posted by lhquam View Post
I am not sure why anyone would prefer to use 2 heatsinks with the V2 combo board. The 50 mm MOSFET spacing is too close. That spacing would be optimal spacing for a heatsink that is 100 mm wide.
With the new change, I'm not sure how I'm going to be implementing my design now.
Here's my sink profile:
The section is 7" wide and if you look close enough, it is raised in the middle. The older V2 design would be ideal as the devices would be close to the raised center bit, which is also the thickest.
As part of building it I was having it milled fully flat and also using a copper heatspreader, but the devices being close to the bulky bit of the sink would have really helped. I was putting two of these side-by-side, for a 14" wide case.
My F5 used one sink per channel, here it will be two monoblocks with two sinks each, about 12" tall each - four feet of heatsink should be sufficient for a stereo V2.
Me sad with the new V2 design
Old 26th February 2012, 04:05 AM   #705
Very interesting heatsinks. The single MOSFET boards have a pitch of 35 mm and should work with those heatsinks. The main downside is that a separate input stage card must be mounted and wired. It might be prefereable on those heatsinks to mount the MOSFETs vertically rather than side-by-side.
Old 26th February 2012, 04:22 AM   #706
Would have preferred to not use wires.
I was thinking of a large 3"x8mm copper bar as a heatspreader.
Old 26th February 2012, 08:50 AM   #707
Andy
Please can I ask for an extra two holes on the input board. These would be somewhere C5 and R29 (perhaps near the kink in the track) and between C6 and R30. These will help people building the balanced version to enable the cascade devices to share the same reference voltages as per Papa's schematic.
So in the balanced version R25, R27 C5, R26, R28 and C6 will be omitted. Two wires will then join the corresponding points on the two boards.
Old 26th February 2012, 09:16 AM   #708
CeeVee is offline CeeVee  Portugal
CeeVee's Avatar
Andy,
Please change my V2 amp PCBs to 4,
Leave PSU at 2 please.
great work you have achieved on these PCBs
Old 26th February 2012, 09:44 AM   #709
Originally Posted by chalkandtalk View Post
Andy
Chalk,
Papa's schematic for the balanced V3 is simplified.
I don't know that you will omit those components. Perhaps somebody else could comment. Papa does say that sharing the same reference voltages is not a requirement.
There is already a provision to connect the two input boards together. A jumper is used across the two positions marked ----link---- if an SE version is being built, if a balanced version is being built the farthest right position connects to the other input board.
When you say holes, I presume you mean pads?
Old 26th February 2012, 11:02 AM   #710
Ferrari is offline Ferrari  Netherlands
Andy,
Please put me down for:
4x V2 Combo boards
2x PSU boards
Thanks!
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 11:05 AM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
Copyright ©1999-2017 diyAudio
