F5 Turbo Circuit Boards
Old 24th February 2012, 02:04 AM   #571
Daniel(Del) is offline Daniel(Del)  Brazil
Originally Posted by jacco vermeulen View Post
100mA bias, Burp too !
Sorry, what do you mean?
Old 24th February 2012, 09:04 AM   #572
rdk845 is offline rdk845  United States
I guess he means that if one wants 100 watts or so level heat dissipation in that configuation the bias needs to be ~100ma.
I was just making some quick calculation on impact of rail voltage increase in V3 and realized that I was underestimating heat sink requirement.
For example, if the bias is 1A per mosfet in Daniel's configuration, heat dissipation per channel is 1kw. My F5 has 12inch 8 inch , 1 inch long fin for 62w. For 1Kw dissipation, I would need 3.3m long heat sink!
Since many main stgream high end speakers's power requirement comes from not the overall low efficiency, but very high current requirement in low frequencis due to dips in impedance and phase rotation, one should make careful consideration of their speaker's requirements.
Of course if what you want is to drive 80db efficiency speakers to 120db, that's different stroy, but that's really not my thing!!
Old 24th February 2012, 09:22 AM   #573
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Sorry
I mean that this is the Papa forum.
For sub-optimal Class AB you are in the dead wrong place, and me no explain why so, therefore the answer is Burp !
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 24th February 2012, 02:07 PM   #574
UKToecutter is offline UKToecutter  United Kingdom
Guys,
Back in the loop. Had no internet access yesterday when I was away.
Anyhow, here is the single Mosfet output board.
Andy
Old 24th February 2012, 02:08 PM   #575
size is 38mm x 50mm
Old 24th February 2012, 03:12 PM   #576
Westley is offline Westley  United States
Andy,
Please change my request to 4 V3 input boards, 4 V3 output boards, and 4 PSU boards as I am building mono amps. Thank you for your excellent efforts.
Rick
Old 24th February 2012, 03:16 PM   #577
Westly,
you'll need 2 x V3 output boards + 1 V3 input board + 1 PSU per channel.
If you're going balanced, you'll need 4 x V3 output boards + 2 x V3 input boards + 1 PSU per channel.
I think........ :-)
Old 24th February 2012, 03:21 PM   #578
Andy,
Thanks. My idea is to go all out and build 4 balanced mono amps.
Rick
Old 24th February 2012, 03:22 PM   #579
So you'll need 8 of the output boards
Old 24th February 2012, 03:23 PM   #580
To explain.
Each out put board is for either the P or N channel mosfets, not for both.
F5 Turbo Circuit BoardsHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 12:05 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 08:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 09:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 08:21 PM
Copyright ©1999-2017 diyAudio
