F5 Turbo Circuit Boards
Old 23rd February 2012, 02:13 PM   #541
Bksabath is offline Bksabath  United Kingdom
Banned
Universall snap in capacitor
fit all sizes from 40 to 30 and different pins that I know off
if one is missing give me lay out and I will put pad there (takes a couple of minutes so no prob
+ leds so if you can see troug case ...
Look at lay out for type and dimentions if you look at screw therminall they all came in 13.5 mm pitch so much beter different board
And at 2 times the rated riple current for same price of snap in cunterpart is no contest
I have made this as there is a common + pad for all sizes board is phisicaly larger this way but works much beter
What one spend on board size is saved with reduced holes numbers
Old 23rd February 2012, 02:21 PM   #542
a.wayne is offline a.wayne  United States
Sin Bin
BK,
I see you 're at the top of the DIY matching transistor Unit GB list , great to have friends in high places ...
Hint , hint .........
Old 23rd February 2012, 02:47 PM   #543
Banned
Originally Posted by a.wayne View Post
BK,
Sorry wayne what you on about. the curve tracer?
What friends no one likes me.
Old 23rd February 2012, 03:03 PM   #544
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Farting in public again, but a universal board would be one for just one row of cap cans, with mounting holes, and holes/pads for resistor leads.
Line 'm up, stack them on pcb poles, or place two side by side, solder the Panasonic or nuked MPC power resistors inbetween.
Or just use a hole of each board to connect a chassis-mount Caddock/Isabellenhütte/IRC-TT/Bourns/Sfernice, or Dale RH/NH in a desired package.
(isn't this the hangout for AH's no one likes ? )
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 23rd February 2012, 03:08 PM   #545
AudioSan is offline AudioSan  Norway
it is for F5 turbo. so no single rail will ever be used.
Old 23rd February 2012, 03:18 PM   #546
Nope, but it saves square inches of pcb, and offers endless variety options.
Back when, me built stacked CRC, with standing power resistors between 1st and 2nd storey/story electrolytics pcb.
Old 23rd February 2012, 03:28 PM   #547
lloop9 is offline lloop9
I second Jacco's recommendation of stacking PSU pcbs, looks neat & save on casing size. We don't want no elephants sitting in our homes right?
Old 23rd February 2012, 03:29 PM   #548
oh. like that
Old 23rd February 2012, 03:36 PM   #549
Define elephant.
In a Class A amp, single row PCB's have the added advantage that air can flow on both sides of an electrolytic, cooler.
(me also undress lytics, better cool-off, look sexy and sounds better, ask Guido Tent if you don't trust a psycho)
Old 23rd February 2012, 03:41 PM   #550
MASantos is offline MASantos  Portugal
since we're talking caps, I 've been trying to understand the reason for going with screw in instead of snap in capacitors. The srew tipe are larger, more expensive, and seem to need extra mounting hardware. I can understand that these have in general better ripple current and esr ratings, but what measurable/audible differences can one expect from using them in a class A amp such as the F5T, if same capacitance is used. Screw in caps are at least double the price of similar snap in units from what I've gathered.
F5 Turbo Circuit BoardsHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 07:12 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 08:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 09:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 08:21 PM
