#481 |
This went from simple to complex very quickly
![]() Has no one considered two monoblocks with sinks on the front? That's 17" wide and doesn't need to be deep at all. Can route the input and output to either the rear, sides or (in my case) the top. I am glad to see the V2 is still one board. That's the one I'll be interested in, if it's still around when the GB goes live. My case is about 14" wide x 5" tall with the heatsinks mounted to the front of the case. The sinks themselves are 10"(h) x 7 (w)" so the front of the sink (where the fins are) rises 5" above the case top, I used one per channel in the original F5 and got a ~30 degree differential in Indian summer. Planning on two per channel with a copper heatspreader, stuck side by side to create a 14" wide case. I just need a little more gain and a little more power, so the V2 is spot on for my requirement. I/O terminals for each monoblock are on the case top. |
#482 |
Hey, Is there allerady some universal PSU PCB done which can be used for any of the F5? Need two of them to power up my dual monos.
![]() Jernej |
#483 |
Wow, Over the weekend I was thinking that "there is no way that I could make V3 other than monoblock even for the starters, should I back out of the board GB?"
Then boom the thread exploded. I'm very happy to see what V3 boards has become. I gotta love this community!. It really isn't much more complicated. Actually, I'm in more of camp prefering wiring individiual mosfet off from board so that builder can use whatever heat sink combination they want. For example, I'm currently considering using 4 of those semikron heatsinks per channel for each monoblock. But width of 2 semikron heatsink would be 250mm. So if the output board is 250mm long, it could be slightly too long. As for those who are concerend about cost of monoblock, I think this V3 turbo version is going to provide a performance that couldn't be generally found in DIY audio community before. If properly built, it could legitimiately compete with multi 10K high power solid state amplifier driving multi 10K or even more expensive main stream speakers. I'm trying to build a 100W class A amp to drive my b&W matrix 800, but would eventually build it into 300W class A amp to drive full range electrostatic speakers. I would spend $1K more if neccessary, to build one properly with room for enhancement. Thanks for the great work Toecutter. Last edited by rdk845; 22nd February 2012 at 10:38 AM. |
#484 |
Indulge me, why is that so ?
Not so much,.......if it says "ZM" in the corner. |
#485 |
#486 |
#487 | |
If you wanted to add additional boards for more output devices I guess you could. Papa is OK as long as I don't use his name or FirstWatt on the boards. |
#488 |
O.K. I meant "generally" couldn't be found in diy audio community. Of course I'm sure many have built word class amplifiers for their own, but F5T would probablly easier and presumably will be much more popular than those inidividual build.
#489 |
Has anyone considered a 3-MOSFET per rail version of the F5-Turbo? It could probably me designed to the exactly the same FET spacing and board dimensions of the BA-CO v2.0 Burning Amp Complementary Output Board, or the F4 V2.0 board. This would allow its use on 10 wide heatsinks like the HeatsinkUSA E007.
Just a thought. |
#490 | |
How about a simple modification to the V5-Turbo V3 Output board that would allow it to have 2 N-ch and 2 P-ch MOSFETS? Cut the gate drive trace and the power trace in the middle of the board and add jumpers for the "normal" 4-of-the-same-kind use. |
| F5 Turbo is posted | Nelson Pass | Pass Labs | 589 | 1st March 2013 01:19 AM |
| F5 clone boards (inc PSU boards) | Tazzz | Swap Meet | 18 | 24th January 2013 12:43 AM |
| F5 turbo problems | Rob Dingen | Pass Labs | 17 | 11th January 2013 08:38 PM |
| F5 Turbo ............. if only !!!!!! | a.wayne | Pass Labs | 23 | 21st January 2012 02:24 AM |
| UGS Boards and F5 boards | DUC985 | Swap Meet | 0 | 7th January 2009 07:21 PM |
