#471 |
I will not need more than 50 watt class-a from F5 Turbo .....
#472 |
Nor will I.
I will probably only populate with two pairs of outputs. The second set of boards will be as spares if I decide to go bigger later. Glad the mono/stereo debate is over. To each there own, I may mount the heat sinks on the outside wall outside and spray water on them when I want to listen to music. I have a garden right under that so I can grow strawberries in the winter and corn in the summer. Rush |
#473 |
Toecutter, could you list the options and features you are considering? MAybe we can have a vote. With enough volume it may spin off in several different versions of boards?
#474 |
I've relaid the original board as an F5 V2, so two N & two P Channel Mosfets on the board.
It seems the general consensus is that the V3 needs to have split N & P channel boards for each channel. Also, The V3 requires one power supply per channel and the V2 can work fine on a single power supply board (stop me if I'm boring you). SO.... A V3 will require 4 x Output Mosfet boards, 1 x 1st Stage Board and 2 x Power supplies. A V2 will require 2 x V2 Combination Boards and 1 x Power Supply. Firstly if someone can check that for me. Secondy, the cost of a test batch is prohibitivly expensive (then again so is getting the boards wrong). I could really do with some of you experts to review the boards against the schematics. I really don't want this to go wrong. Andy |
#475 |
Oh, forgot to say.
All the boards have alternative resistor positions for Caddock and Futaba resistors. |
#476 |
#477 |
This monoblock configuration would work for a 180 watt F5-turbo.
The dimensions are 15"x11.5"x6". It might need to be slightly larger for the bigger toroid transformer. I have actual temperature measurements for 2 x F5 channels at 65W dissipation per channel with only 12C-14C temperature rise. |
#478 | ||
That's 4 boards /ch for a v3 .....? Quote:
Sweeeeet .............. V3 lives !!!!! Last edited by a.wayne; 22nd February 2012 at 03:00 AM. |
#480 | ||
Not necessarily split N & P boards. I would just use 2 of your output boards in parallel. Quote:
V3 per channel: 2x Output board, 1x 1st Stage Board, 1 PS board. Preferably in one mono block V3 stereo: 4x Output board, 2x 1st Stage Board, 2 PS board. Preferably in two mono blocks V3X per channel: 4x Output board, 2x 1st Stage Board, 1 PS board. Preferably in one mono block V3X stereo: 8x Output board, 4x 1st Stage Board, 2 PS board. Preferably in two mono blocks Oh... V2 stereo 2 x V2 Combination Boards and 1 x PS board. Stereo chassis is ok For checking the layout and schematics there are better experts here. Any news from Papa regarding his OK? |
| F5 Turbo is posted | Nelson Pass | Pass Labs | 589 | 1st March 2013 01:19 AM |
| F5 clone boards (inc PSU boards) | Tazzz | Swap Meet | 18 | 24th January 2013 12:43 AM |
| F5 turbo problems | Rob Dingen | Pass Labs | 17 | 11th January 2013 08:38 PM |
| F5 Turbo ............. if only !!!!!! | a.wayne | Pass Labs | 23 | 21st January 2012 02:24 AM |
| UGS Boards and F5 boards | DUC985 | Swap Meet | 0 | 7th January 2009 07:21 PM |
