Old 21st February 2012, 11:44 PM   #451
Originally Posted by a.wayne View Post
@ AudioSan ..
Spare me , my last Class-a amp drew 1400 watts from the wall at idle ... I have walked this Forrest before ....
without fans? or watercooling?
aleph P1.7 pre. F5 power amp. CDpro2(need DAC).
Vivaldi8 speakers
Old 21st February 2012, 11:47 PM   #452
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Originally Posted by lhquam View Post
If the mono-blocks were square, then you could stack them with one rotated 90 degrees relative to to other and not have the heatsink air-flow compromised for the mono-block on top.
should look lovely ....
Originally Posted by labjr View Post
Well, I can't imagine why else anyone wouldn't want boards which will benefit more people since it seems impractical to have a board with 8 outputs on it running high bias class A. Will run too hot. Only make sense to me that many will be discouraged from building something so complex in one chassis. Obviously, it isn't gonna be a project for frugal builders. So the easier it is to build, the more interest it will attract.
AGAIN !!!! ...
I'm not against any of this, I was address Mr San's redonculous statement that it would be cheaper, it is not, i don't care if toe made a PCB for each output , personally i would prefer 14 outputs /ch , yeah , maybe i will push for that , this way we could choose 2/4/8/12/14 ...
Being serious as JV, i could use more outputs , what say you .....
Old 21st February 2012, 11:48 PM   #453
a.wayne's Avatar
No fans , Krell KSA200 ........
Old 22nd February 2012, 12:02 AM   #454
Krell KSA-200S
Krell's new KSA-200S is a large stereo chassis, conservatively rated at 200Wpc into 8 ohms (23dBW). The rating continues to double down to a 1 ohm loading, where a 1600Wpc output is specified. Krell's proprietary output-stage bias system delivers dynamic class-A operation up to the maximum 8 ohm power rating, with an increasing proportion of class-AB operation with the higher current associated with lower load impedances. This "Sustained Plateau" biasing scheme is said to offer the sonic benefits of pure class-A without the massive energy inefficiency and correspondingly huge, hot heatsinks. The energy-conscious KSA-200S idles at 120W. If it ran in pure class-A, it would have to idle at around 1kW—over eight times as much wasted energy drawn from the wall.
funny that the 200S only idles at 120W?
Vivaldi8 speakers
Old 22nd February 2012, 12:05 AM   #455
and so big sinks
Vivaldi8 speakers
Old 22nd February 2012, 12:08 AM   #456
a.wayne's Avatar
No, not that one , the one before , the real 200 watt class-a . that one is not full a full class-a 200watter , it has "plateau Bias"....
This one ...
Old 22nd February 2012, 12:15 AM   #457
tehrkn is offline tehrkn  Greece
Please include me for 4 amp and 8 PS boards.
Thanks a lot.
Old 22nd February 2012, 12:19 AM   #458
that was some monster heatsinks to.
need to be 0.017C/W total.
guess it is 600-700mm deep?
Vivaldi8 speakers
Old 22nd February 2012, 12:22 AM   #459
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
0.325A bias per Motorola, 77Vdc rails, makes 25W.
Six on each heatsink, 36 total, makes 900W dissipation.
The heatsinks Krell used on the 200B are 0.30C/W, so they ran stupidly hot.
Why they broke down so often.
Now back to our regular scheduled program.
Not so much,.......if it says "ZM" in the corner.
Old 22nd February 2012, 12:27 AM   #460
that tells it all i wonder. had that happend with monoblocks at 2/3 the hight and same sink type and depht? no.
Vivaldi8 speakers
F5 Turbo is posted Nelson Pass Pass Labs 589 1st March 2013 01:19 AM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 18 24th January 2013 12:43 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
Copyright ©1999-2013 diyAudio
