F5 Turbo Circuit Boards - Page 45 - diyAudio
Old 21st February 2012, 11:30 PM   #441
OK,
Now laid out to allow for Caddock and Futaba Resistors
Old 21st February 2012, 11:31 PM   #442
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by MASantos View Post
If we cut the traces in the middle of the board, add jumpers in the middle of the board?
Depends on how many would be interested in that option, i'd think.
If it's a mere 1 in 10, more appropiate would be to grab a dremel to cut the traces.
In that case, 1-2 pairs of added mounting holes in the center of the board would be sufficient.
The remaining 9 of 10 would have to install the jumper, not particularly rational, no ?
Lovely board, Mr Andy sir.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 21st February 2012, 11:35 PM   #443
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by UKToecutter View Post
OK,
Sweeet .......
Old 21st February 2012, 11:36 PM   #444
Originally Posted by a.wayne View Post
Are you worried about the cost ..? did i say i was worried about the cost ? San said it would be cheaper , I'm pointing out it is not...
Interesting to see how many of you actually build Mono's .....
a lot will build mono's, of F5 v3 that is.
there is a reason that you never(almost) see a 2x100W+ class A stereo amp.
i'm talking about 100W class A not A/B.
so a power draw of 450+W of the wall.
without fans that is. that was the whole point here.
Old 21st February 2012, 11:38 PM   #445
I could adapt the previous layout as a V2 only removing the additional 2pairs of MOSFETs.
Shouldn't take too much time.
Old 21st February 2012, 11:38 PM   #446
Sin Bin
@ AudioSan ..
Spare me , my last Class-a amp drew 1400 watts from the wall at idle ... I have walked this Forrest before ....
Old 21st February 2012, 11:39 PM   #447
Sweeet .......
This one is 250 x 50 with the FETs at 66mm centres.
Odd number but I wanted to keep them apart.
If the concensus is to make the board longer I can do that.
Old 21st February 2012, 11:41 PM   #448
lhquam is offline lhquam  United States
Originally Posted by AudioSan View Post
thank you
and yes. stacking to monoblocks will take less room then a stereoamp. but you need good space between them. the best will be to place them side by side in the middle of the rack. think thats easyer too. depending on your setup of course.
If the mono-blocks were square, then you could stack them with one rotated 90 degrees relative to to other and not have the heatsink air-flow compromised for the mono-block on top.
Old 21st February 2012, 11:41 PM   #449
labjr is offline labjr  United States
Well, I can't imagine why else anyone wouldn't want boards which will benefit more people since it seems impractical to have a board with 8 outputs on it running high bias class A. Will run too hot. Only make sense to me that many will be discouraged from building something so complex in one chassis. Obviously, it isn't gonna be a project for frugal builders. So the easier it is to build, the more interest it will attract.
Old 21st February 2012, 11:42 PM   #450
Sin Bin
@Toecutter,
The spacing sounds appropriate, I'm using a baseplate anyway, not sure what the others have in mind ..
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 11:05 AM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
Copyright ©1999-2017 diyAudio
