F5 Turbo Circuit Boards - Page 4 - diyAudio
Old 12th February 2012, 04:41 PM   #31
CeeVee is offline CeeVee  Portugal
CeeVee's Avatar
It's amazing how much yours is similar to mine Bksabath.
Mine is still alfa, need to check it still but this layout can be expanded easily....
also working on a version with transistors on right and left....will post if there is interest.
Old 12th February 2012, 04:57 PM   #32
Send a message via MSN to chchyong89
I like yours the most now... it's simply neat and good!
www.stoneracoustics.com
Old 12th February 2012, 05:14 PM   #33
labjr is offline labjr  United States
Would be interesting to see a rectangular board with outputs on both sides since about the best heatsink available in the states is from Heatsink USA and the deepest one they make is only 10 inches.
I did noticed the manual mentions mono blocks. Would it work well to have all the N channel devices on on side and the P channel devices on the other heatsink?
Old 12th February 2012, 05:21 PM   #34
6L6 is offline 6L6  United States
6L6's Avatar
If you use a single sink, yes, but if you are willing to make a frame to hold more than one together, you have infinite depth. FWIW, the hifi2000 cases, at 400mm or bigger are all multiple heatsinks.
That's more of an issue with the layout of the PCB than anything else. It's one one the reasons Peter Daniel makes his PCB as small as possible, it actually gives you more choices with how things are mounted and gives more flexibility in what kind of sinks you use.
Old 12th February 2012, 06:50 PM   #35
Banned
I like it beter than mine.
Yes cascodes is what I have at the moment and that is going to be the way I am going to make it as well.
2 toughts
1) I may put a couple of resistors in series with P3 last time I tried that I fried the Jfets.
2) I already have MYF5 with most of the bits in place apart from the diodes I wonder how much different the F6 is going to be.
Old 12th February 2012, 07:15 PM   #36
Ooh. That is a work of art. I am shamed!!!!
Back to the drawing board to do an imitation :-)
Old 12th February 2012, 07:17 PM   #37
CeeVee's Avatar
Originally Posted by 6L6 View Post
It has always humored me how many people clone the FirstWatt designs using the long skinny boards. If you have ever seen the FirstWatt heatsinks in person, or a really good photo of them, you see why the boards are arranged like that.
But... with the heatsinks that are available to the DIY community, however, a smaller and more rectangular board is highly advantageous. You can still make a highly symmetrical board, but IMO smaller is actually better.
The one i posted is for the community....221 x 36 mm...but i do agree with you, I prefer the more rectangular ones for my heatsinks, that is why i'm working on the other version with the active power devices, 4 each side. 87 x 127...
Old 13th February 2012, 10:09 AM   #38
CeeVee,
Can you check your P3 connections.
I think they're going to the wrong side of the input FET's (i.e. should be S on the 170 and D on the 74).
Andy
Old 13th February 2012, 10:37 AM   #39
CeeVee's Avatar
Thanks Andy,
I've corrected that mistake...doing rest of board and will post later after full review.
It's source on both ! not Source and Drain...
Old 13th February 2012, 10:42 AM   #40
Thanks Andy,
Of course (which is why I've just made a hasty modification to my schematic!!!)
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 11:05 AM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
Copyright ©1999-2017 diyAudio
