F5 Turbo Circuit Boards
Old 23rd December 2013, 05:59 PM   #2321
mk57 is offline mk57  United States
I've searched but have not found a helpful guide to the wiring on the latest store boards I've started my build but a little confused on how to link up all of the OP connections etc.
and what is the link connection use for?
Old 23rd December 2013, 06:46 PM   #2322
BobEllis is offline BobEllis  United States
BobEllis's Avatar
If memory serves most of us will connect the "link" to ground. Those building an balanced "X" version will use it to connect to the other front end board to make it an X amp.
Old 23rd December 2013, 06:51 PM   #2323
AudioSan is offline AudioSan  Norway
here is a drawing from the old Boards. but the conections are about the same.
the link is used just for balanced amp configuration. With a standar stereo amp the link is shorted to sig. gnd.
Old 23rd December 2013, 08:04 PM   #2324
Old 7th January 2014, 08:05 AM   #2325
Mallard is offline Mallard  Germany
Question regarding wiring of diyAudio pcbs.
Please see my litle principle sketch below. Does this make sense? Especially the O/P to the speaker!?
I'm wondering if it makes a difference when I use the very right side output connection from the pcb instead of the centered O/P connection of the gain stage pcb.
Thanks in advance for your help!!!
Old 8th January 2014, 02:40 PM   #2326
BigE is offline BigE  Canada
BigE's Avatar
Is the link the only difference between SE and balanced? obviously, the inputs will be + and -, but do any parts values need to be changed?
Old 8th January 2014, 02:59 PM   #2327
there will be som value changes. but there is never made any schematics with values for a balanced version. as far as i know.
Old 8th January 2014, 03:14 PM   #2328
BigE's Avatar
I guess LTspice could help.
Old 16th May 2014, 03:20 PM   #2329
BigE's Avatar
Are schematics for the DIYaudio store FE vs Output boards available?
Old 16th May 2014, 05:12 PM   #2330
flg is offline flg  United States
flg's Avatar
Like these maybe?
http://www.diyaudio.com/forums/image...-schematic.pdf
http://www.diyaudio.com/forums/image...-schematic.zip
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
F5 Turbo Circuit BoardsHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 07:12 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 08:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 09:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 08:21 PM
