F5 Turbo Circuit Boards - Page 231 - diyAudio
Old 11th November 2013, 05:36 AM   #2301
henryve is offline henryve  South Africa
henryve's Avatar
@emyeuoi
The process I refer to is Vacuum Impregnation. Basically it prevents the windings from moving excessively with the fluctuating magnetic fields induced, which is the usual cause of mechanical hum. Old style potting of the whole transfomer may also help, but I don't believe as much as Vacuum Impregnation since the latter process fills the cavities between the windings better.
Old 11th November 2013, 05:51 AM   #2302
emyeuoi is offline emyeuoi  Italy
emyeuoi's Avatar
Thanks for the clarification
Old 11th November 2013, 07:13 AM   #2303
emyeuoi's Avatar
Anyway they are from Primerose and I suppose that they well know which kind of technic should be used to avoid the mechanical hum...
Old 22nd December 2013, 03:12 PM   #2304
Default F5T for headphone?
I am going to build a scale down version of F5T for headphone. For simplicity sake, (1) the current limiters are removed and (2) the thermister are also removed. But, I am not sure whether I have to retain the 2.2k resistors attached to the thermistors in the original schematic suggested by NP. 1/4W resistors will be used except R13 ~ R16, which are 1 ohm non-inductive rated at 2W. I am going to bias output at 100 ~ 150mA. Any comments on the schematic and PCB layout?
Old 22nd December 2013, 11:32 PM   #2305
Rush is offline Rush  United States
Why don't you use 2sk2013 / 2sj313 instead of hard to get Fairchild outputs?
Probably sound better too!
Rush
Old 22nd December 2013, 11:42 PM   #2306
6L6 is offline 6L6  United States
6L6's Avatar
By comparison the Fairchild are easy - the K2013/J313 are rapidly becoming genuine unobtanium.
Buzzforb has lots of Fairchild.
Old 23rd December 2013, 01:51 AM   #2307
Rush and 6L6
Thank you for the input.
I had done a simple research on the net before I made a post here.
I stick to Fairchild after I checked their availability and price on RS components.
Some of the alternatives are either unavailable or too expensive e.g. Toshiba 2Sk1530/2SJ201 pair.
6L6, I have ordered some Fairchild already and expect to receive them this afternoon.
Since I am not going to parallel the MOSFETs, is matching the N-P pair important?
Old 23rd December 2013, 02:06 AM   #2308
you dont need dobble up of source resistors and feedback resistors.
but you might want to get the source resistors close to the output transistors.
you don't need TO-247 transistors. TO-220 is plenty. you can also drop C1-8.
and it is not a scaled down F5 turbo, but a scaled down F5
Old 23rd December 2013, 02:43 AM   #2309
and i would not drop the thermistor circut. it's there to keep the bias stable.
Old 23rd December 2013, 02:54 AM   #2310
AudioSan,
I used TO-220 footpin in the PCB for the MOSFET but did not change the FQA to FQP in schematic. Sorry for the confusion.
You are right. At low current, it may not necessary to double the resistors. I will re-allocate the position of source resistors after the deletion of the doubled resistors.
Regarding the 10u caps., they are founded in the Turbo V1 schematic in the Pass article. The 10u caps are not seen in the original F5.
Agree with you. The 330u may not be necessary. Because 100mA constant current is more than enough to drive most headphones that 300u caps are not needed for high transient load. Is my understanding correct?
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 11:05 AM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
Copyright ©1999-2017 diyAudio
