F5 Turbo Circuit Boards
Old 1st November 2013, 05:21 PM   #2291
Mallard is offline Mallard  Germany
What are the source resistor values?
Did you finish your biasing meanwhile? What is the result?
Originally Posted by emyeuoi View Post
Buzz, I am using the diodes and the source resistor that was in your premium GB.
Based on that which is in your experience the maximun mV that I can reach during the bias?
Old 2nd November 2013, 01:39 AM   #2292
emyeuoi is offline emyeuoi  Italy
emyeuoi's Avatar
As per original schematic: 2 resistor 1 ohm in parallel.
I complete the biasing at 360 mV. Right channel is stable while the offset of the left is not so stable. Rechecked after 1 week and the offset value move from 0,2 to 17 mV. Re-biased at 0,0 mV and I will re-check time to time.
The result? Astonishing... I was expecting a good result but, togheter with the DCB1, the whole setup is fantastic. The only flaw... trafos are slightly humming
Old 2nd November 2013, 11:51 AM   #2293
Ok, thanks Emyeuoi. What kind of trafos do you use?
Old 2nd November 2013, 03:34 PM   #2294
emyeuoi's Avatar
Two Primerose toroidal 600VA 24V to get 32 Vdc rial. 2 separate PSU each one with the softstart.
Old 2nd November 2013, 04:48 PM   #2295
And what kind of caps?
Old 3rd November 2013, 01:34 AM   #2296
emyeuoi's Avatar
The caps are nr. 8 22.000 50V for each PSU. Those caps was part of the F5T Premium kit GB organized by buzzforb that also included the parts for the PSU (the caps, the bledder and filter resistors and the diodes). The PCBs are from TeaBag... Thanks TeaBag
.... and Thanks Buzzforb
Old 11th November 2013, 04:43 AM   #2297
henryve is offline henryve  South Africa
henryve's Avatar
Those transformers are not supposed to hum. Do you have DC blockers on the primary side of the transformers? The hum could be caused by DC on the main supply line.
Old 11th November 2013, 04:52 AM   #2298
emyeuoi's Avatar
Those trasformers are not supposed to hum but they hum. I [just] replace the transformers 2 weeks ago and the hum disappear... is a mechanical hum
Old 11th November 2013, 05:02 AM   #2299
henryve's Avatar
Oi! Not good. Did you specify that the windings must be dipped to dampen mechanical vibration? It should be standard with these big VA transformers I believe.
Old 11th November 2013, 05:10 AM   #2300
emyeuoi's Avatar
Sorry but I can specify only that they are humming, I have not the skill to identify why they are humming
F5 Turbo Circuit BoardsHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
