F5 Turbo Circuit Boards
Old 8th September 2013, 12:35 PM   #2281
buzzforb is offline buzzforb  United States
buzzforb's Avatar
If building an F5T, the bias limit is determined by the diodes Vf. If you want to increase or lower bias, you must also change the source resistor values. If not using diodes, it is a non issue.
...Shape the sound , Man!
Old 8th September 2013, 12:43 PM   #2282
emyeuoi is offline emyeuoi  Italy
emyeuoi's Avatar
Buzz, I am using the diodes and the source resistor that was in your premium GB.
Based on that which is in your experience the maximun mV that I can reach during the bias?
Old 8th September 2013, 01:27 PM   #2283
buzzforb's Avatar
I would max it out at between 380 and 400mV across the across the source resistors until you get the temperature performance stable. You can bump it a little after that, just be careful. This amp can get away from you faster than most if you have it biased too high and the diodes cut on. Highest I have had mine is 420mV.
Old 8th September 2013, 01:31 PM   #2284
emyeuoi's Avatar
Noted... I will not go more then 470 mV as mentioned on the FirstWatt article.
Thank for the advise
Old 8th September 2013, 02:00 PM   #2285
Russellc is offline Russellc  United States
Originally Posted by WalterW View Post
but when do you get your trafos? Then you should be nervous....
Just make sure the bias trimmers are in the right position before you start...I measured every potentiometer twice with the ohmmeter just to be sure..
But you are right it's always a very exciting moment switching the 230V... those big donuts can destroy everything...
I have mine set to the middle, hope this wont be a problem. I will be firing up with a variac, like I did with "regular" F-5. Is this sufficient sans light bulb tester? Or is this amp so twitchy the pots must be zeroed even with variac?
Thanks,
Russellc
Pass B-1 preamp, Pass BA3 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre
Old 8th September 2013, 02:08 PM   #2286
buzzforb's Avatar
IF you have a variac, you will be fine. Low and SLOW.
Old 8th October 2013, 11:15 PM   #2287
SRMcGee is offline SRMcGee  United States
SRMcGee's Avatar
Folks:
Can someone explain the purpose of Q1.1 and Q2.1 to me? I understood that cascoding helped to spare Q1 and Q2 from having to bear voltages beyond their meager capacity, which is why Q7 and Q8 are in the circuit. What do Q1.1 and Q2.1 add, and are they required in all implementations of the F5T?
Scott
Good decisions are derived from experience; experience is derived from bad decisions (unknown)
also, "Everyone has a plan, till they get punched in the mouth" (Mike Tyson)
Old 8th October 2013, 11:48 PM   #2288
AudioSan is offline AudioSan  Norway
Q1.1 and Q2.1 is there so you can paralell 2 J-fet pairs to get higher Idss.
Old 9th October 2013, 12:36 AM   #2289
6L6 is offline 6L6  United States
6L6's Avatar
In a build with lots of output fets there is a possibility to run out of oomph in the driver stage. The .1 Jfets allow paralleling for the reason AudioSan mentions, and also if you need more current to run lots of output mosfets.
Remember this design can scale up towards the ridiculous - especially in terms of how much heatsink you need...
Great meeting you at Burning Amp, It's always nice to attach a real face to a forum member.
Old 9th October 2013, 12:02 PM   #2290
SRMcGee's Avatar
AudioSan and 6L6:
Thanks for the explanation!
6L6:
Not to go off-topic (very much), but I also enjoyed our conversation at Burning Amp and appreciated the time you took amidst the bustle to hang out. I'm already looking forward to next year....
Scott
F5 Turbo Circuit BoardsHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
