F5 Turbo Circuit Boards
Old 6th August 2013, 01:05 AM   #2221
nashbap is offline nashbap  United States
[QUOTE=Lordi;3579471]
but i don't like two things.
there is not enough space between the mosfets. if the bias is about 0.8 A/output device, and the railvoltage is about 32 volts, it would be about 200 watt dissipation. For this, i need a bigger distance between the mosfets for large heatsinks.
?QUOTE]
Wouldn't you be better off from the standpoint of heat distribution to put all four n or p output devices spread out in a straight line? That way you can mount the devices near the horizontal center of the heat sink for the most even heat transfer.
Old 29th August 2013, 12:06 AM   #2222
Russellc is offline Russellc  United States
Default Heat sink spacing w/ store 5U and Tea-bag boards
Seems like I remember someone asking if Teas boards can be used on the heatsinks (on the store 5u deluxe chassis box) and the response was (I thought) that some lower holes may need drilled, but otherwise would work.
I am not finding an easy way to equally space the two pairs in my V2, at least not so that the fets line up with the pre drilled holes, and if I jerrymander it to do so, it seems they are not centered on the sink, but closer to the center line
between the sinks.
Do I have to run wires from the fets from the board? How have others mounted their V2 with teas boards to these heatsinks? Should I have just got "blank" heatsinks with no holes and ddrilled myself? Even then, the board doesnt allow me to center the fet and diode in the sinks center area, but closer to the center line between the two sinks.
If anyone has a pic and can tell me what holes had to be added, I would appreciate it greatly. I like Teas boards and obtained them over the store board version. However, after the expense of the case and other turbo doo-dads, I really didnt want to jerry rig this amp. Maybe I'm not seeing the best way to do it, but I am about to conclude that I should mount the board to four of the board mounting post positions, and run short wires to the legs of the devices. Is this a valid way to do it? Surely someone out here has figured this out?
I dont mind drilling and tapping more/new holes...if I have to. Also, if wires are used, is that sufficient or do some of the resistors have to be move off board and closer to its mosfet? Similarly, the TH1 and TH2...I guess the Fet by the TH parts could be mounted to the board so that thTH part will reach it, and run wires to the balance of the other fets?
Russellc
Pass B-1 preamp, Pass BA3 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Amp, Pass M-2 amp, Pass Aleph J amp, Pass Pearl 2 Phono pre
Old 29th August 2013, 12:09 AM   #2223
buzzforb is offline buzzforb  United States
buzzforb's Avatar
If you want to mount the diodes to the sink, you will have to tap holes. Is this at the core of your question?
...Shape the sound , Man!
Old 29th August 2013, 12:35 AM   #2224
No Buzz, its the centering of the two pair of mosfets....I havent decided whether or not to mount the diodes on the sink or not, no big deal if I do and need to drill holes. If I get one set of two pairs centered, the other pair isnt in the center of the other sink, in fact one is on the wrong side of the sink, and the other too close to that same side....
The core of the question is, how does everyone space them properly, or is it impossible with these boards and leads need be run. If so, does this create any problem with one pair on leeds, one pair not? And if this is the method, do any of the resistors need to be moved off board to be closer to the fets made remote via the leeds?
Russellc
Old 29th August 2013, 12:38 AM   #2225
Wait a minute, I'm having brain fart....I'm thinking pairs are side to side, they are across from each other....let me stare at this a little longer....but if there are suggestions on positionoing I am all ears!
Much appreciated,
Russellc
Old 29th August 2013, 12:47 AM   #2226
About the best positioning I can find so far, is with the Q10 + Q12 pair located at the holes that are the third set from the crack between the two sinks....this leaves the other pair Q3 + Q5 pair at a set of holes as well, same positioning on the sink, third set of holes from the center crack. This would leave re-drilling and tapping the board stand off holes, (4) and a few if I decided to mount the diodes to the sink. Only problem I see with this is that the pairs are not directly centered on the sinks, but both pairs slightly closer to the center line...maybe at the 1/3 point instead of the 1/2, or center point.
Russellc
Old 29th August 2013, 12:52 AM   #2227
buzzforb's Avatar
It's up to you and what you are willing to do, but you could mark off 20mm c to c and position for best dissipation. Perhaps not perfectly centered on sink, but should be fine, heat wise.
Old 29th August 2013, 01:04 AM   #2228
Well, tell me...right now they are "centered" not too bad, just not centered. Measuring from the center between the two sinks, ONe pair is about 1/3 of the way in one direction, the other pair about a third of the way the other direction. If they would go 1/2 the way in each direction, they would be centered, so I am not that far off? The center of the two pairs is 4 and 3/4 inches apart.
Russellc
Old 29th August 2013, 01:11 AM   #2229
buzz, if you look at the UMS specification drawing, there is a green dot in the center. There is a row of holes going across the sink just below this green dot.
Starting at the center just under the green dot and you count three holes to the right and also 3 holes to the left, these are the positions the Mosfets would be attached to. Is this enough spacing?
Russellc
Old 29th August 2013, 01:13 AM   #2230
buzzforb's Avatar
I think you will be fine. PKI had F5T on 5u sink. It got warm, but was ok. I think V3 was pushing it a bit if I remember correctly.
F5 Turbo Circuit BoardsHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
