F5 Turbo Circuit Boards
Old 26th July 2013, 03:58 AM   #2211
noSmoking is offline noSmoking  United States
noSmoking's Avatar
Default That's great!
Originally Posted by Earthquake View Post
Hi noSmoking thanks for the reply I have received the information via a PM so I have the info I need.
Good luck to you!
NS
Old 26th July 2013, 03:11 PM   #2212
BigE is offline BigE  Canada
BigE's Avatar
The F5T document says that the outputs are paralleled. I'm assuming that the store output boards can also be paralleled from a single FE board.
Old 27th July 2013, 02:38 AM   #2213
6L6 is offline 6L6  United States
6L6's Avatar
Yes, they can. You need a second set of PCB, but there are connections to add another set of output boards daisy-chained off the first set.
Old 29th July 2013, 01:56 PM   #2214
Lordi is offline Lordi  Germany
Default Board for F5T V3 balanced
hi, i want to create my own pcb board for a balanced f5 turbo v3, and i'm struggling with one thing. there will be a single gainstage board, two p-channel boards and 2 n-channel boards. now my question: do i need a GND on the n-channel/p-channel boards? is it bad to have no caps on the n/p-channel boards? i'm very grateful for your answers :-) here a picture of the schematics (i know, the p-channel MOSFETS are n-channel MOSFETS, but i'm to lazy to create a new library) f5tbalanced8jwx3y9obz.png auf fotos-hochladen.net
Old 29th July 2013, 02:26 PM   #2215
oh, i saw a little mistake, here the correct schematic f5tbalancedewi8ku4m0x.png auf fotos-hochladen.net
Old 29th July 2013, 08:01 PM   #2216
BigE's Avatar
Thank you!
Old 30th July 2013, 08:43 PM   #2217
alex mm is offline alex mm  Romania
alex mm's Avatar
...... how about this ?
Old 30th July 2013, 09:11 PM   #2218
noSmoking's Avatar
Default hi alex
Those look nice ,have you got a set made for proto yet?
I would like to make a set of those when they are proven,lol.
Thanks,
NS
Old 30th July 2013, 11:24 PM   #2219
thats a nice layout
and balanced output is possible with two boards.
but i don't like two things.
there is not enough space between the mosfets. if the bias is about 0.8 A/output device, and the railvoltage is about 32 volts, it would be about 200 watt dissipation. For this, i need a bigger distance between the mosfets for large heatsinks.
if two boards are assambled there is no thermal coupling from the "left" channel jfets/cascode to the "right" channel jfets/cascode.
for now i'm finishing the layout for the gainstage board, and post it tomorrow.
maybe someone has a little hint for the n-channel and p-channel boards. i really don't get it, is a cap (about 10 µF) or a gnd on the n-channel and p-channel board a must-have?
Old 31st July 2013, 05:34 PM   #2220
i'm not ready with my pcb's, but here are my first results
what do you think?
F5 Turbo Circuit BoardsHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
