F5 Turbo Circuit Boards
Old 14th July 2013, 01:02 PM   #2191
6L6 is offline 6L6  United States
6L6's Avatar
The transformer used in my build is 143mm diameter x 79mm tall. It is 600VA.
Old 14th July 2013, 01:24 PM   #2192
emyeuoi is offline emyeuoi  Italy
emyeuoi's Avatar
Hi 6L6, thanks for the info and congratulation for the guide... very useful
Cheers
Old 14th July 2013, 01:27 PM   #2193
6L6's Avatar
Thank you.
One of these days, when I get a bit of time to apply to this, I will actually get the guide finished.
Old 14th July 2013, 01:30 PM   #2194
emyeuoi's Avatar
Thank you.
Old 14th July 2013, 04:48 PM   #2195
Rixsta is offline Rixsta  United Kingdom
Originally Posted by emyeuoi View Post
PS: sorry, one of the picture is upside/down... here in the correct side
emyeuoi
Looks like we are pretty much at the same stage, I am using the same Boards as you. and only one PSU by Tea.
I had blown one channel of my amp and had a ground loop, members here recommended I get teas boards. So will soon rewire everything with them.
But will closely watch your progress, The Wiring scheme I am going to have to think hard about as not to make the same mistake as last time! I notice that the PSU has 3- 3+ and 6 Ground connections on the output, Very usefull so will see how you wire them as realy am not sure of the best way.
Anyway nice work
www.rikibuckingham.com... DIY=Zen V4, Zen-lightenment‎, Jean Hiraga 20w,
ACA, F5, F5T, Audio Freaks Club
Old 14th July 2013, 07:33 PM   #2196
AudioSan is offline AudioSan  Norway
no smoking. this is the wrong diagram. delete it and forget it
her is the correct one
Old 14th July 2013, 07:41 PM   #2197
noSmoking is offline noSmoking  United States
noSmoking's Avatar
Hi audiosan,
consider it done,
Old 15th July 2013, 01:26 PM   #2198
emyeuoi's Avatar
Originally Posted by Rixsta View Post
emyeuoi
Anyway nice work
Hi Rixsta, sorry for the late reply. I read on the threads that you have a loop ground problem. I am just progressing on my first build and I can't help you in detail but as I understand from Buzz and reading in various threads in the forum the only way to avoid ground loops is having only one star ground on the Front End board. In this way the 6 ground connections on the PSU unfortunatelly are not usefull and you have to connect all the ground cables in the same point and back to the PSU with only one (big size) ground cable.
I hope that my understanding is correct and this is best way and I am sure that somebody in the forum will give us all the support
Anyway, I will keep post the progress... All my best for your re-wiring
emyeuoi
Old 20th July 2013, 10:22 AM   #2199
Thanks emyeuoi
Im just in the process of sorting some things and wiring up, the diagram above as reference for the boards, and also will drill a hole where you have as thats a great idea
I see what you mean about having to wire them all to the same point as star ground.
I know this point can be at the Front End boards but thought it might be able to be at the PSU output too.
Anyway on with the progress.
Old 20th July 2013, 10:34 AM   #2200
emyeuoi's Avatar
Hi Rixsta,
My progress will be very slow... I am looking for a aluminium plate as support for all the PSU pcbs and soft-start but I can't found anything here. I hope I can get solve soon and proceed with wiring.
F5 Turbo Circuit BoardsHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 12:05 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 08:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 09:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 08:21 PM
Copyright ©1999-2017 diyAudio
