F5 Turbo Circuit Boards
Old 1st May 2013, 02:43 PM   #2111
R.I.P.
That looks familiar.
It is Bensen's original sheet.
regards Andrew T.
Old 2nd May 2013, 06:51 PM   #2112
Daniel(Del) is offline Daniel(Del)  Brazil
Hi all!
I'm interested in some of Tea-Bag's boards, however he has currently run out of them.
So if you also want some, please show interest here, so that he can produce a new batch: https://docs.google.com/spreadsheet/...zdrWm9lYzgtOVE
Thank you very much
Daniel
Old 3rd May 2013, 02:14 AM   #2113
rubofdagreen is offline rubofdagreen  United States
I have a pair I would be willing to sell. I cannot use them, account of my dumpster reclaimed heat sinks, (needed the modular ones from the store). Whatever he charged me plus shipping.
Old 4th May 2013, 09:40 PM   #2114
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Usual Excuses: Family Issues, Day Job, other PCB/chassis issues...
BUT the circuit board sets are now individually labeled, packed and SENT by UPS to the order fulfillment center. Should get there in 2 days plus 2-3 days processing on their end and they'll be in the store. The fulfillment people are more reliable then I as it IS their "Day Job"
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 11th May 2013, 10:46 AM   #2115
coolnose is offline coolnose  Europe
coolnose's Avatar
Default F5T boards in stock in the Diyaudio store as per NOW!
just a quick note to let everybody know that F5t board are now in stock - US warehouse only though!
Store notification mail does not seem to work, at least not for me.
I have placed my order....
Max
Old 11th May 2013, 08:18 PM   #2116
diyAudio Editor
Variac's Avatar
Yes they are in stock at last! And they will only be in the USA store for now. The VAT thing is tricky for us and our store..
Old 20th May 2013, 01:30 AM   #2117
a.wayne is offline a.wayne  United States
Sin Bin
Variac ,
What happened to the 8 output pr model, Are we able to use the current 5 pc setup and add the additional outputs ..?
Regards ..
Old 20th May 2013, 07:34 AM   #2118
diyAudio Editor
Variac's Avatar
You have to get 2 sets.
Old 20th May 2013, 06:59 PM   #2119
Sin Bin
Thanks ....
output circuit board dimensions ...?
Originally Posted by coolnose View Post
Any opinions ?
Yes ...
Originally Posted by AndrewT View Post
post2103:
is that 70degrees of phase angle at 4ohms @ ~40Hz
& ~45degrees @ 3ohms @ ~60Hz?
Those will be very demanding of the output stage and drivers with short term loads.
At 40 to 70Hz the tones could be quite sustained. Could high levels of these bass tones these blow up the output stage?
Not if he runs enuff and keep them within SOAR....
Yes Andrew, that's the way to read the graph!
Hence ,my question: As much Power into 4 ohms as possible (higher rails) or as much "class A" as I can get from lower rails ?
Your amp will have to be able to sink power continuously into 2 ohm to not have bass issues when driving that load, noticed you have the port tuning at a low 20hz, what size driver ... ?
Old 21st May 2013, 09:08 AM   #2120
coolnose's Avatar
Originally Posted by a.wayne View Post
Thanks ....
Yes ...
Wayne,
quoting you " if he runs enough ****" , I guess you wanted to write bias "bias" ?
Driver is 15"
Max
F5 Turbo Circuit BoardsHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
