F5 Turbo Circuit Boards - Page 211 - diyAudio
Old 27th April 2013, 10:29 PM   #2101
that is a very high bias/low rail voltage v3. are you running low impedance speakers?
Old 27th April 2013, 10:53 PM   #2102
given for 8 Ohms, but having some heavy dips, I have an impendance curve somewhere...
I read the multiple power calculation in this thread...as everybody I'd like to stay class A as long as possible... but I need to re-read that calculations again
Old 28th April 2013, 01:46 PM   #2103
Default Impedence plot
Any opinions ?
Old 29th April 2013, 11:26 AM   #2104
Originally Posted by Variac View Post
I assure you the PCB's won't be close to the most expensive parts. By the time you build the power supply and get enough heatsinking!
We've decided to release the rest of the boards right away, which means about a week for them to be in stock...
That should be this week then...
Old 30th April 2013, 12:58 PM   #2105
post2103:
is that 70degrees of phase angle at 4ohms @ ~40Hz
& ~45degrees @ 3ohms @ ~60Hz?
Those will be very demanding of the output stage and drivers with short term loads.
At 40 to 70Hz the tones could be quite sustained. Could high levels of these bass tones these blow up the output stage?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 1st May 2013, 10:38 AM   #2106
Originally Posted by AndrewT View Post
post2103:
Yes Andrew, that's the way to read the graph!
Hence ,my question: As much Power into 4 ohms as possible (higher rails) or as much "class A" as I can get from lower rails ?
Old 1st May 2013, 11:21 AM   #2107
Examine the reactive load temperature de-rated SOAR for the loadings your impedance plot is showing.
Clue:
use Bensen's, or other, SOAR calculations.
regards Andrew T.
Old 1st May 2013, 12:17 PM   #2108
Andrew,
I am totally willing to have a closer look, your indications don't help me though.
Could you tell me what you mean by SOAR - I am pretty sure not a jordan village or cognitive architecture.
If it's "Safe Operating Area" then I would just need a hint on where to find information on Bensen.
Thanks,
Max
Old 1st May 2013, 12:56 PM   #2109
He's in the Threads
I have posted many times offering a modified version of Bensen's spreadsheet that can be applied to FETs and BJTs and other changes.
Bensen's work is based on David Eather's paper. That is referenced in the spreadsheet.
regards Andrew T.
Old 1st May 2013, 03:36 PM   #2110
Andrew,
if the spreadsheet you are referring to is something like project1.xls and all I have to do is enter my device data, my rail voltage and my capacitance for the power supply, then I think I'am safe for 8 and 4 ohms...
See attached pdf.
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 12:05 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 08:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 09:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 08:21 PM
Copyright ©1999-2017 diyAudio
