F5 Turbo Circuit Boards - Page 21 - diyAudio
Old 19th February 2012, 02:09 AM   #201
Rush is offline Rush  United States
Originally Posted by UKToecutter View Post
OK.
Power supply is re-laid.
Dimensions are now 176mm x 154mm.
Phew!!!
Caters for 25mm standard and 30mm snap in Caps.
Yes,it does look great! I like the shorter board, leaves room for transformer.
Rush
Old 19th February 2012, 02:21 AM   #202
Nice article. I don't see the small value bipass capacitors in nelson's design though. Wouldn't be too hard to add those, could easily be soldered nthe bottom of the board, directly to the large capacitors pins.
Old 19th February 2012, 03:01 AM   #203
I've made provision on the board for the optional capacitors.
Old 19th February 2012, 03:19 AM   #204
OK Power Supply done (again).
Starting to look quite complex now with the bypass caps on.
Unless there is a glaring ommision (is there?) I'll consider these as final.
Old 19th February 2012, 04:54 AM   #205
sangram is offline sangram  India
Here's hoping for the best!
I don't want any PSU boards, BTW. Like Jack I prefer hardwiring the PSU in place. Keeps me careful about my soldering, too
Old 19th February 2012, 07:41 AM   #206
Send a message via MSN to huseying
Hi everyone
here is mine pcb for V1
its so simple and clear but need some tweak ı think,ı will so
ı'll appreciate ıf someone will comment
keep in touch to f5 tuRBO
My ebay tube store
http://www.ebay.com/usr/hgungor10
Old 19th February 2012, 08:03 AM   #207
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
I thought one bypass cap per rail was good enough. I've never seen so many laid out like that before. But that's only my observation.
Thanks for all the good work!
Salas Boards GB 2017#1 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards Out of stock
Old 19th February 2012, 09:24 AM   #208
Itsmee is offline Itsmee  England
Itsmee's Avatar
... I'll consider these as final.
If you move the C4 to R1-7 track to the top of the resistors, that leaves a clear path to from the bottom of R1-7 to C10.
Another minor change I would make is to sum all the 0V tracks at the output connection.
Old 19th February 2012, 09:58 AM   #209
Tea-Bag
Looks like I miss-read the article by Scott Faller.
Now one bypass cap per rail on the output (150nF) and one per rail on the input (100nF).
Board back to 166mm long.
Old 19th February 2012, 11:34 AM   #210
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
done (again)
Mind if i ask why the 16 caps ?
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 11:05 AM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
Copyright ©1999-2017 diyAudio
