F5 Turbo Circuit Boards - Page 208 - diyAudio
Old 24th April 2013, 04:26 AM   #2071
dazed2 is offline dazed2  Canada
BTW just received the new boards!
So is there somewhere buried in the threads somewhere a build guide for these boards? especially when using 4pr? where do you connect the gainstage to the MOSFET board, and whats the best way to link the two boards to the speaker output and ground?
Old 24th April 2013, 11:54 AM   #2072
a.wayne is offline a.wayne  United States
Sin Bin
Buzz you see that , 4pr , ha , you slow poke .......
Old 24th April 2013, 12:15 PM   #2073
buzzforb's Avatar
did you see this? Or are you asking for official V3 with store boards?
BTw, I have built up 5 amps in two months. I am slow, but diligent.
...Shape the sound , Man!
Old 24th April 2013, 02:03 PM   #2074
Sin Bin
Well , hows the 4 pr .......
Old 24th April 2013, 02:46 PM   #2075
6L6 is offline 6L6  United States
6L6's Avatar
The guide is coming.
What version are you building?
The FE board has labels that correspond to the attachments on the Output boards.
Speaker out is attached to the top of the FE board marked 'O/P' Speaker Ground is attached somewhere on the bottom to GND.
Yes, you will run out of holes. Ground will need to have some type of buss.
Old 24th April 2013, 05:07 PM   #2076
buzzforb's Avatar
I noticed a big difference in V2 vs standard F5. I did not notice as big a difference with V3, but I think there is a simple explanation. V2 gave me all the power(headroom) my drivers needed or wanted and v3 really didn't add anything, other than DF. I would expect those who would see an improvement from V3 over V2 are those who need the extra power, like yourself. I clearly hit the ceiling in gain. THat being said. V2/V3 was a completely different animal than the F5. In your case, I would suggest multiple output pairs and less per fet bias. I am working on a f4 output board that could be easily converted to work as output to f5 Fe, if you are interested. NOt going to produce it, but I know you have a special need for power, due to your speakers. I currently have 6 pairs on the board spread out over about 16", using universal mounting spec.
Old 26th April 2013, 01:17 AM   #2077
I'm building the full out V3 with 4pr.
So in the case of 4pr is there benefit of running wire directly to each connection hole of the output boards? or one wire split close to the boards to the gates and O/P at the output board be ok?
Also, what would be the best way to connect the speaker out when I have 4pr (2N and 2P boards ?)
Old 26th April 2013, 01:21 AM   #2078
buzzforb's Avatar
Lay everything on piece of poster board. Innclude outline of sinks, bottom, back and front. Draw in boards, fets, switches, toroid, inputs, and then draw out layout. Use erasable markers, as you will be changing it. Either that or invest in big bottle of white out
Old 26th April 2013, 01:34 AM   #2079
ha ha well thats done on solid works ...... . for the case
Old 26th April 2013, 01:37 AM   #2080
buzzforb's Avatar
It actually helps with wiring as well. The store boards will take some consideration, being modular.
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 12:05 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 08:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 09:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 08:21 PM
Copyright ©1999-2017 diyAudio
