F5 Turbo Circuit Boards
Old 12th April 2013, 02:57 AM   #2031
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by buzzforb View Post
This weekend.
If i were to build them, monoblocks would be only consideration. I would probably go balanced over SE as you get voltage on the cheap and can get away with higher bias as a side benefit. 22V rails should get you 100W into 8 ohms all day long with only 20W dissipation per fet.
My v3 will be with Tea's boards and will be biased as high as I can get them. I will show single channel of store boards and full stereo of Tea's
Cant use balance low -z is 1 ohm plus all my kabizillion pieces of equipment , none are balanced ...
Old 12th April 2013, 03:03 AM   #2032
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I remember you telling me this. Have you considered more outputs and less bias or even ba/f5FE driving BA PP output? For V3 into 1R load, your gonna need 9-10A totdl bias. I would bet on 6 output pairs unless changing output Rs.
...Shape the sound , Man!
Old 12th April 2013, 03:19 AM   #2033
dazed2 is offline dazed2  Canada
Originally Posted by 6L6 View Post
The layout of the amp is winding up to be a fairly critical point of this build - the seperate front-end board (the driver circuitry, so to speak) is on it's own PCB and has many connections that all need to be wired in a way that isn't conducive to making the amp unstable - and as this is such a wide-band hotrod amp, it needs attention paid to make it work.
The FE board being it's own piece makes it possible to make a V1, V2 or V3 all with the same physical board set. Cool!
Well that was what I was getting at, what special considerations should one be looking at when laying it out? I'm making one with 4 pr and originally layed out with Tea's board. so that means I have wires going all over the place in a monoblock!
With the DIYaudio release still lots of wires, but connected to another PCB instead of the Mosfets.
Old 12th April 2013, 03:57 AM   #2034
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Eager for a diagram on how to do the balanced!
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 12th April 2013, 05:10 PM   #2035
Mr. dB is offline Mr. dB  United States
Mr. dB's Avatar
BA3B might give some hints...
Old 12th April 2013, 05:28 PM   #2036
buzzforb's Avatar
f5X build thread might be better source. Check out the build thread. Euvl walks through teh initial biasing of amp in balanced mode.
Old 12th April 2013, 06:39 PM   #2037
AudioSan is offline AudioSan  Norway
or the F5turbo article.
Old 12th April 2013, 07:25 PM   #2038
Sin Bin
5 pr should work, 30 volt trans.............
Old 13th April 2013, 12:17 AM   #2039
Oh also noticed the set allow for 2 pr / channel is this correct?
How do we order more of the break out boards for a full 4 pr / channel?
Old 13th April 2013, 12:33 AM   #2040
6L6 is online now 6L6  United States
6L6's Avatar
4pr/channel will take 2 sets of boards. Esentally you will use all the output boards per channel.
You will wind up with a couple extra FE boards that way, which with a little planning and modification you can probably make a BA-3 gain stage for a preamp project or something.
F5 Turbo Circuit BoardsHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
