F5 Turbo Circuit Boards
Old 11th April 2013, 04:11 PM   #2021
dazed2 is offline dazed2  Canada
Originally Posted by labjr View Post
Each MUR2030 is a double diode.
Ahh right, thanks.... Looks like I bought too many diodes then .
Old 11th April 2013, 04:12 PM   #2022
Originally Posted by buzzforb View Post
I have had one fired up and tested, but no music ever played through it. Layout will be important.
Could you explain what you mean by layout?
Old 11th April 2013, 05:59 PM   #2023
Rixsta is offline Rixsta  United Kingdom
Personaly from experiance i think in certain places leads need to be kept not too long and also for instance audio leads kept away from power leads.
This way there is less likely to apear noise in the audio circuit and is less likely to oscillate.
My old Zen amplifier had leads from the Mosfets to the PCB so long that it was very unstable.
www.rikibuckingham.com...
Old 11th April 2013, 11:14 PM   #2024
a.wayne is offline a.wayne  United States
Sin Bin
Well spill the beans , a 4 pr min is my only interest .....
Old 11th April 2013, 11:28 PM   #2025
6L6 is offline 6L6  United States
6L6's Avatar
Originally Posted by a.wayne View Post
Want to build a 4 pr version , is this possible with these beta boards .....
Yes, with a cascode front-end and the other bits as mentioned about the V3 in Nelson's article.
I'm interested in it as well, but am very curious what you have in mind for chassis/heatsink. Do you have anything in mind or purchased? I think everybody would be interested in sourcing information for that project.
Old 11th April 2013, 11:41 PM   #2026
Sin Bin
Chassis would be custom built already have the materials ...
18W x 14H x17 deep it will be fan cooled on top of big sinks..... 80 watt class-A @8 ohm and very load tolerant, has to be 1 ohm stable and happy ..
Old 11th April 2013, 11:55 PM   #2027
6L6's Avatar
Good! You understand that it needs to be enormous!
Doubled input jfets, cascode, compensation caps, 800VA transformer -- all these things are going to be part of your build.
Old 12th April 2013, 12:05 AM   #2028
6L6's Avatar
The layout of the amp is winding up to be a fairly critical point of this build - the seperate front-end board (the driver circuitry, so to speak) is on it's own PCB and has many connections that all need to be wired in a way that isn't conducive to making the amp unstable - and as this is such a wide-band hotrod amp, it needs attention paid to make it work.
The FE board being it's own piece makes it possible to make a V1, V2 or V3 all with the same physical board set. Cool!
Old 12th April 2013, 12:37 AM   #2029
buzzforb is offline buzzforb  United States
buzzforb's Avatar
This weekend.
If i were to build them, monoblocks would be only consideration. I would probably go balanced over SE as you get voltage on the cheap and can get away with higher bias as a side benefit. 22V rails should get you 100W into 8 ohms all day long with only 20W dissipation per fet.
My v3 will be with Tea's boards and will be biased as high as I can get them. I will show single channel of store boards and full stereo of Tea's
...Shape the sound , Man!
Old 12th April 2013, 02:55 AM   #2030
Sin Bin
800...! Nope using 1kva /ch .......... No trans hum for me ..
F5 Turbo Circuit BoardsHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
