F5 Turbo Circuit Boards
Old 1st April 2013, 09:47 PM   #2001
sts9fan is offline sts9fan  United States
Patience is not a virtue I posess.
Old 1st April 2013, 10:11 PM   #2002
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Ok, OK we'll release some to the store. They appear to be workin' ok..
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 3rd April 2013, 10:45 AM   #2003
Rixsta is offline Rixsta  United Kingdom
www.rikibuckingham.com...
Old 3rd April 2013, 10:56 AM   #2004
bnorrish is offline bnorrish  United States
bnorrish's Avatar
April Fools!
Old 3rd April 2013, 11:43 AM   #2005
6L6 is offline 6L6  United States
6L6's Avatar
It wasn't supposed to be an April Fools joke...
Old 3rd April 2013, 12:07 PM   #2006
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
You mean : It wasn't supposed to be an April joke, Fool !
( © B.A. Baracus )
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 3rd April 2013, 06:32 PM   #2007
bnorrish's Avatar
Perhaps I deserve to be called a fool. It was not meant to be mean or make light of all the hard effort put into this. I did find myself checking the store the the last couple of days. A lot of interest in this thread and the boards. Not to read the tea leaves but I was always curious if people were having issues testing - if that was the case we could all possibly learn from it.
Old 3rd April 2013, 07:26 PM   #2008
diyAudio Editor
Variac's Avatar
Yes it would be better to have each tester sum up their experiences here and where they are in the builds at this moment. There are various amps working, but always, some small item isn't perfect, but that doesn't mean the boards are flawed. Also some don't use all the boards, etc.
I'm packing the boards into their bags as they will be sold as one item
Old 3rd April 2013, 07:29 PM   #2009
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Dark Alley talk. I had built 3 successful V2 builds and one channel of v3 with no issues. I also helped fire up a 4 amp that was a v2. all of these used TeaBags boards. 6L6 got the store boards and had some trouble. Kept burning fets. Was able to get one up and running and burnt it through torture test with his sig generator. Mark was kind enough to send a pair my way for testing. I fired it up with no issues. made the amp clip at 1K,10K, and 20K. No issues. EVen hooked up the rats nest wiring wrong, cooking small 10uf coupling capacitor on signal board. Blew the damn thing up like an M80. Replaced it, plugged the rails up properly, and all was fine. I have yet to find anything to worry about, but it might be wise to use C3 in V2 and above. It simply cuts off some of the bandwidth in the amp to reduce possibility of oscillation. F5 is WIDEband amp. I have not seen any oscillation as of yet. Will do final testing this weekend by hooking it up with cap as load. Its an attempt to make it oscillate. F5T is advanced amp simply because of power levels involved. But if you are careful, follow instructions, all should be fine. A variac is an indispensable item to have if serious about amp building. You can find them for very good prices used. It allows for a great deal of safety in the turn on procedure.
...Shape the sound , Man!
Old 3rd April 2013, 07:43 PM   #2010
6L6's Avatar
I have let the smoke out of my V2 a few times. Oscillation for unknown reasons twice -- the was fixed by larger value gatestopper resistors and the addition of the compensation cap from gate to rail. (Shown in the V3 schematic)
The last time was during a torture test, feeding it a 40kHz squarewave of sufficient amplitude to drive the amp just under clipping. Don't do that.
I strongly suggest using the compensation cap (1000pf) in all builds and increasing the gatestopper resistors to 470ohm or thereabouts. (I'm using 680ohm, on the suggestion of Wayne Colburn)
The build guide is being worked on at this very moment.
F5 Turbo Circuit BoardsHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
