Old 16th March 2013, 02:54 AM   #1971
6L6 is offline 6L6  United States
6L6's Avatar
Haven't gotten to F6 yet.
F5T boards available soon.
llustrated Build Guides - Pass Pearl 1 - Pass B1 - - Pass F5 - Pearl 2 - -O2 HPA - -
Pass F4
Old 16th March 2013, 05:17 AM   #1972
Originally Posted by buzzforb View Post
Threads can get tedious. I tend to be a big part of that. Then again, if it was all just facts and figures, it would be boring. You can always start s new thread with any questions you have. Welcome.
Theres alot of truth to that post, but if it wasn't for your help, along with others. We wouldn't get the help needed, we just have to learn or understand what the heck your saying half the time(or maybe thats that Zen fellow who claims his papa is smarter then mine).
Just having fun guys, I enjoy reading your very informative post.
If I cant build it or fix it I really dont want it.
Old 16th March 2013, 04:34 PM   #1973
WalterW is offline WalterW  Netherlands
Chassis is almost ready... just waiting for the frontpanel from Andrea in Italy
I made a little sub-chassis for the heavy transformers and want to put the rectifying bridges (16 diodes) beneath it. So the 'noisy' BYW99 diodes and ugly 50 Hz cabling are shielded and out of sight.
Do you think the subchassis will hold the dissipation of these diodes ? Or will it become too hot?
A little math: P=UxI, so 0.7 volts x 2,5 Amp per diode = 1.75W x 16= 28 Watts...thats a lot of rectifying heat!
Or is my calculation wrong?
The Teabag amp boards and capacitor boards will be mounted on the heatsinks.
At last I can start with the electronics....although the chassisbuilding was nice also
Should I make the backpanel black too??? I'm in doubt.
Thanks for EUVL whose chassis in the F5X thread was my reference...
File Type: jpg diodes beneath transformer-chassis.jpg (231.3 KB, 194 views)
half Swiss, half Dutchie....
Old 16th March 2013, 04:52 PM   #1974
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
yo half Dutchie
which diodes you're going to use ?
how many channels per chassis and what's Iq per channel and how many Graetzs per channel ?
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 16th March 2013, 04:56 PM   #1975
The ones from Jacco: BYW99-W200 from ST.
Old 16th March 2013, 05:01 PM   #1976
Zen Mod's Avatar
aaaargh ...... Dutch Connection
lookielookie : http://pdf1.alldatasheet.com/datashe.../datasheet.pdf
rest of questions ?
Old 16th March 2013, 05:06 PM   #1977
Teabag F5T convertible boards, stereo dual mono setup. With two 2sj201 and two 2sk1530 per channel which i want to bias a bit higher around 1.25A per MOSFET. So with 32 volt around 40 Watt dissipation each.
These MOSFETS are so big and the heatsinks also, so I think they will hold...
total of 160 Watt per heatsink, but if it's getting too hot, I give them around 1 Ampere bias.
Graetzs? ah Google is my best friend... one rectifying bridge a rail (4 diodes/rail) so 16 Graetzs
Old 16th March 2013, 05:08 PM   #1978
Originally Posted by WalterW View Post
........... Or will it become too hot?
Or is my calculation wrong?..........
16 diodes for two channels seems like four power rails each with four diodes. That can only come about by having a bridge rectifier on each of four secondaries.
Now look at a secondary with a bridge rectifier.
One pair of series rectifiers passes current in one direction. The other pair of rectifiers passes current when the AC phase is reversed. That means the rectifiers operate @ 50% duty cycle.
Apply 50% duty cycle to your 28W for an effective 14W when the diodes are passing 2.5Arms to the smoothing caps.
Q: what is the rms current charging the smoothing capacitors?
If you were to adopt a single bridge on a pair of secondaries you could reduce the heat losses in the remaining eight rectifier diodes to just 7W.
Old 16th March 2013, 05:11 PM   #1979
Yep, Dutch connection
Old 16th March 2013, 05:21 PM   #1980
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Yep, very.
Short pulses, higher Vf, but much higher dVxdI product per dissipated diode W.
Not 2.5A continuous per diode.
Not so much,.......if it says "ZM" in the corner.
F5 Turbo is posted Nelson Pass Pass Labs 589 1st March 2013 01:19 AM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 18 24th January 2013 12:43 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
