Old 27th December 2012, 09:47 PM   #1911
N-Brock is offline N-Brock  United States
N-Brock's Avatar
Hi all,
I've got some of the new F5t boards in hand. I'm planning on going V2 monoblocks.
I've got two 25 volt 500 VA transformers I'll be using and some big screw top caps.
Something I can't seem to find is a list for populating the boards in the V2 style. What components are omitted, what needs jumpers, and what parts on Pass' published schematic correspond to part numbers on the board.
The issue is the part numbers on the board don't correspond to the part numbers in the schematic. I've started a spread sheet to straighten things out that I will post. Any help I could get on this would be great.
Best,
Nelson
Old 27th December 2012, 09:59 PM   #1912
it dipends. are you planning on cascoding?
aleph P1.7 pre. F5 power amp. CDpro2(need DAC).
Vivaldi8 speakers
Old 27th December 2012, 10:06 PM   #1913
tinitus is offline tinitus  Europe
boards look really great
but why does it say V2 ? ....with drivers, shouldn't it say V3 ?
Old 27th December 2012, 10:09 PM   #1914
it say v2.0 it was the sec board layout.
Vivaldi8 speakers
Old 27th December 2012, 10:16 PM   #1915
Renron is offline Renron  United States
Renron's Avatar
Pant, pant, pant. Cool looking boards.
any currently open GB for parts ?
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 27th December 2012, 10:21 PM   #1916
N-Brock's Avatar
Ding ding
I forgot to add my spreadsheet of the parts population. I seem to have it all worked out but the more who check the better off we'll be. I'm not sure about jumpers but I kinda think they won't be needed. I'll have to trace out the board in more detail later.
I am not planning on cascoding, my rails will be right around 32 volts which should be fine for the input jfets.
Here's the list.
https://docs.google.com/open?id=0B5A...F9wOS16ZFpEOVk
The forum doesn't take .xlsx (excel) files. If you want the original there's a .zip attached.
Best,
Nelson
Old 27th December 2012, 10:26 PM   #1917
cascoding will not hurt but if you chose not to, you need do short C-E on Q5 and 6.
and drop C5 and C6. also drop R25,26,27,28,29 and 30.
Vivaldi8 speakers
Old 27th December 2012, 10:50 PM   #1918
N-Brock's Avatar
AudioSan, since you seem to be the resident expert could you tell me what the pad labeled "link" is intended for? I could try to guess but I suspect you know for sure.
Thanks,
Nelson
Old 27th December 2012, 11:11 PM   #1919
it is for linking the midpoint of R3 and 4 to ground. as far as i know, it was made as a link for a reason regarding balanced version. so you need to make a link there
EDIT: after a quick check, i see that i was right in balanced version, the midpoint of R3 and 4 are conected to the midpoint of R3 and 4 of ampboard nr2 and not to ground.
Vivaldi8 speakers
Old 28th December 2012, 01:29 AM   #1920
Best if there's build guide to answer these questions.
Pinoy ikaw ay pinoy... ipakita sa mundo... kung ano ang kaya mo...
F5 Turbo is posted Nelson Pass Pass Labs 589 1st March 2013 01:19 AM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 18 24th January 2013 12:43 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
Copyright ©1999-2013 diyAudio
