F5 Turbo Circuit Boards
Old 3rd October 2012, 02:20 AM   #1821
sippy is offline sippy  United Kingdom
Sorry for this off topic post:
For less you could have Hope Pro hubs, decent spokes ie: Sapim and Mavic rims.
Hope hubs last and can be upgraded with ceramic bearings (free hub can be upgraded to 'all in one cassete'), spokes available at any cycle shop worth its salt due to them not being a specific dia to fit silly small gauge hubs.
Old 3rd October 2012, 02:32 AM   #1822
sachu888 is offline sachu888  India
sachu888's Avatar
Thanks all,I will update my build here.
Sachin
Old 3rd October 2012, 02:34 AM   #1823
sachu888's Avatar
deleted
Old 3rd October 2012, 02:39 AM   #1824
sachu888's Avatar
Originally Posted by buzzforb View Post
Sadhu,
I would suggest 18 or 22mF caps over 10mF. The boards look fantastic
Thanks Justin,
I will update my BOM with 18 or 22mf caps.
Sachin
Old 7th October 2012, 06:51 PM   #1825
sachu888's Avatar
Default Cap question
Sadhu,
Hi Buzz,
We are building Dual mono design with 2 Power supply boards and two transformers.Each power supply board will have 8 caps of 10000uf 50V,so total 16 caps of 10000uf. Do you think we need more than 10000uf?
Sachin
Old 7th October 2012, 07:15 PM   #1826
buzzforb is offline buzzforb  United States
buzzforb's Avatar
If your doing V2, then it should be ok for dual mono. More is always good, especially at these current levels.
...Shape the sound , Man!
Old 10th October 2012, 01:46 AM   #1827
rubofdagreen is offline rubofdagreen  United States
One more time
By Buzzforb,
[Sadhu,
I would suggest 18 or 22mF caps over 10mF. The boards look fantastic]
There seems to be several 10mf caps in the BOM. Which caps are you referring to please?
Old 10th October 2012, 02:12 AM   #1828
buzzforb's Avatar
In original article, 8-10mF caps per rail was spec'd for the V2, giving a total of 16 for stereo V2. Fo rV3, two PSU's lik ethis was suggested for dual mono setup, meaning total of 32 caps for stereo V3. When i saw Sadhu's PSU board with 10mF written on it, i was afrai ch ewould not hV eadequatefiltering, having only 4-10mF caps per rail. Because heis doing dual.mono psuboard, it will be OK. I am designing a board for my kit GB memebers that will accept the caps they purchased from me. I fyou have a ?, just PM me.
Old 10th October 2012, 02:52 AM   #1829
Thank you, I try to keep up with these threads when I can. I am still trying to figure out how to make mono blocks out of the boards I have. Is it acceptable to run equal length wires to the output mosfets? I found 2sj74"s recently at mojotone. Hope they are the real thing. Measured well....
Old 10th October 2012, 03:00 AM   #1830
buzzforb's Avatar
Did yiu se pic of my lsst heatsink showing big L aluminnum as heat spreaderM
F5 Turbo Circuit BoardsHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
