F5 Turbo Circuit Boards
Old 21st September 2012, 07:23 PM   #1781
beetle is offline beetle  Germany
3A bias is coming very close to that. Serious heat sinks from fischer or so are really costly. Can buy only two for a modushop case.
Old 21st September 2012, 08:11 PM   #1782
R.I.P.
are you allowing for 3A bias at +-24Vdc from each half of the balanced amplifier?
i.e. 288W dissipation per channel.
3A bias gives ~ 6Apk of ClassA and results in 36W of ClassA into 2r0. This when feeding a 4r0 load from the two halves of the balanced is roughly 72W of ClassA into 4r0. Double the power into double the load impedance.
Working back from your 200W into 4r0 balanced, needs 100W into 2r0 from each half.
That requires a ClassAB output of 20Vpk and 10Apk. Probably a sensible target from +-24Vdc rails biased to a total current of 6A.
regards Andrew T.
Old 21st September 2012, 08:18 PM   #1783
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by AudioSan View Post
beetle. (bias x2) x (bias x2) x impedance /2.
so say 2A bias. it is 4 x 4 x 2 / 2 = 16W class A at 2ohm
or 64 W @8ohm
Originally Posted by beetle View Post
So ~3A bias 24V rails then. I would assume that Modushop 5U 500 has not the right sinks for 576W per channel. Or does it?
1kva 18V toroid will be costly. Any good source in Europe?
I would expect a total power of up to 200W in 4 ohm Class B and 36W class A. Right?
32 watts ...
Old 21st September 2012, 08:30 PM   #1784
R.I.P.
I understood he wanted to bridge the outputs as described in options of the F5t.
That's what I assumed in my response of post1782
regards Andrew T.
Old 21st September 2012, 08:48 PM   #1785
Aren't the speakers seeing the double voltage when bridged?
Old 21st September 2012, 09:20 PM   #1786
AudioSan is offline AudioSan  Norway
[QUOTE=a.wayne;3173877]or 64 W @8ohm
correct
Old 22nd September 2012, 07:14 AM   #1787
R.I.P.
.............correct
yes,
how does knowing that help you?
Do you understand how an amplifier works?
Do you know the difference between ClassA operation and that for ClassAB?
Do you know how a bridged and balanced amplifier operates?
regards Andrew T.
Old 22nd September 2012, 10:51 AM   #1788
Bridging means that one amp is inverted or the signal. Current will remain the same but voltage is double.
Besides this a little, still learning. In this case we have a push pull amp. In this particular F5 design the first stage is splitting the signal in two halves. One inverted. The F5 is class A up to the bias. Then it transitions to class B. I think this describes it well: Push pull amplifier, working and theory. Class A , Class B , Class AB circuit diagram
Still learning.
Old 22nd September 2012, 11:51 AM   #1789
andrew. why do you quote my answer in there??
i answered wayne.
but to answer how it helps to know that.
it makes a huge differnce on the dissipation.
Old 22nd September 2012, 04:32 PM   #1790
R.I.P.
you told him "correct".
I agreed, "yes".
But does the questioner know what he is doing?
Now that Beetle has posted 1788, it is obvious he does not have a clue.
regards Andrew T.
F5 Turbo Circuit BoardsHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
