#1771 |
diyAudio Editor
I was asked whether the new boards will fit the UMS, which is the drilled and tapped hole standard as used in the diyAudio chassis. The answer is YES! that's the point.
To see the standard, go to t he store here: http://www.diyaudio.com/store/ or select it at t he top of this page, then look for this link: PCB Summary (all amplifier PCBs are UMS compliant) the 400mm deep chassis has more holes , as listed in the Standard so will accommodate 2 boards on each side, with MOSFETS and diodes. Four MOSFETS and DIODE per side in other words. the 300mm deep chassis will accommodate one board per side, ie 2 MOSFETS and 2 DIODES per side Alex has laid these out for us per Toecutter's design. He's amazing! We hope that board makers for all projects will use this standard when possible to make building up amps a lot easier!
2013 Burning Amp Festival announced: Sunday, October 6th in S.F. We need Volunteers & sign-up's for what you're bringing! Last edited by Variac; 21st September 2012 at 03:20 PM. |
#1772 | |
aleph P1.7 pre. F5 power amp. CDpro2(need DAC). Vivaldi8 speakers |
#1773 |
variac. you got my mail?
#1774 | |
#1775 |
Depends on the time of year ....
#1776 |
One? I am considering having two of them.
![]() @AudioSan How to calculate the power at 2Ohm Class A? |
#1777 |
beetle. (bias x2) x (bias x2) x impedance /2.
so say 2A bias. it is 4 x 4 x 2 / 2 = 16W class A at 2ohm
#1778 |
pmax = i^2 * rload / 2
For 4Apk you get 16W. In a ClassA push pull output stage , you would need an output bias of >2A in each half of the balanced amplifier. |
#1779 |
So ~3A bias 24V rails then. I would assume that Modushop 5U 500 has not the right sinks for 576W per channel. Or does it?
1kva 18V toroid will be costly. Any good source in Europe? I would expect a total power of up to 200W in 4 ohm Class B and 36W class A. Right? Last edited by beetle; 21st September 2012 at 07:06 PM. |
#1780 |
4U/400 is enough for 100W/heatsink
so , say that 5U/500 is enough for maxmaxmax 150W/heatsink ....... no more
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
| F5 Turbo is posted | Nelson Pass | Pass Labs | 589 | 1st March 2013 01:19 AM |
| F5 clone boards (inc PSU boards) | Tazzz | Swap Meet | 18 | 24th January 2013 12:43 AM |
| F5 turbo problems | Rob Dingen | Pass Labs | 17 | 11th January 2013 08:38 PM |
| F5 Turbo ............. if only !!!!!! | a.wayne | Pass Labs | 23 | 21st January 2012 02:24 AM |
| UGS Boards and F5 boards | DUC985 | Swap Meet | 0 | 7th January 2009 07:21 PM |
