F5 Turbo Circuit Boards - Page 174 - diyAudio
Old 18th September 2012, 09:01 PM   #1731
Rush is offline Rush  United States
Originally Posted by Tea-Bag View Post
Rush, your getting too deep. That said I think we've lost 3 people for sure in my time here.
I have never heard of scanning a PDF to gerber, especially if it's dual sided.
Yes, I was getting too deep. But how would anyone know if you really "lost" someone. The 3 you know of, someone had to tell you about.
I know nothing about gerber files. Seems like with jpg files posted someone could recreate without starting from scratch, but I don't know.
Rush
Old 18th September 2012, 09:31 PM   #1732
buzzforb's Avatar
couple simple solutions. Any board you buy can always be bridged to another to add components. For instance, the chip amp Aleph board can hold 6 big caps and easily be daisy chained for more caps. I have done this personally. The board Tea has showed me will do the same. Main reason a large board has not been done is size. The smallest I have been able to get a board that will hold all 8 35mm caps is 7" x 8". That is big, but when talking about 100W Class A, it goes with territory. I can assure you that a case to house an amp with that kind of dissipation will have the space. I am sure that Tea will do whatever, but i would imagine some sort of commitment is in order. If nothing comes about, I will make a layout available for those who want to etch at home.
...Shape the sound , Man!
Old 19th September 2012, 05:47 AM   #1733
wijgers is offline wijgers  Netherlands
Hi Audiosan/Variac,
Good news the F5T boards are continued. as I understand from previous posts you will continue with V2 and V3 as separate boards. Will the V2 also be as a all in one board like UKToecutter did in his V2 Combo?
Nils
Old 19th September 2012, 06:09 AM   #1734
anilva is offline anilva  India
Default Can I use a Metal bridge rectifier instead of MUR3020W
For the F5T V2 build can I use a 50A, 1000 PIV Metal bridge rectifier instead of a bridge made out of MUR 3020W as Papa has suggested. I don't have space on the power supply PCB to accommodate the diodes and hence this question.
Will there be any noise issues on the DC side. The cap bank is 8 X 10000 microfarads per rail.
Thanks.
DIY F5, F5T, F6, Aleph J, Fostex 206 based BLH, Altec Onken with 515 LF & 288 HF, Technics SP10 MKII & EMT950 turntables
Old 19th September 2012, 07:45 AM   #1735
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
The boards will not be all one board. There will be a gain board with 2 channels, and N output boards and P output boards. Each board has 2 MOSFETS and 2 diodes. For the big diyAudio 5U x 400 deep chassis you can put two of the boards on each side, ie 2 P's on one side and 2 N's on the other side, or one P and one N on each side.
This is quite versatile as you can make mono-blocks or 2 ch amps,
With 2 output devices per side or 4 per side.
And they all bolt onto the drilled tapped holes on the diyAudio chassis heatsinks. the chassis' will be in stock in the next week or 2 .
I explained the modular boards earlier on this thread. Maybe someone can find the posts.
"The geek shall inherit the earth"
Burning Amp thread here on diyAudio [/B]
Old 19th September 2012, 07:46 AM   #1736
diyAudio Editor
Variac's Avatar
UK Toecutter just disappeared. Maybe he got busy, or bored, or sick of people constantly suggesting changes!
(including me- I started the whole modular board thing, but they needed to fit the new chassis' as there is a lot of interest in using them
for this project). There was some concern that his diodes on the PSU board didn't have adequate heatsinking.
Old 19th September 2012, 07:58 AM   #1737
I built up a 5off 15000uF cap bank (+-75mF per channel) for the 100W KSA Klone.
It put out over 450W into 2r0 and supply ripple was tolerable. See report from a few years back.Krell KSA 100mkII Clone
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 19th September 2012, 12:59 PM   #1738
Thanks.
that will work just fine
Old 19th September 2012, 01:12 PM   #1739
imix500 is offline imix500  United States
imix500's Avatar
Thanks.
Just remember to heatsink the bridge adequately.
Old 19th September 2012, 02:01 PM   #1740
here is the boards gain stage board is breakable so it can be used in monoblock.
for 2 ch you need:
V2: one dual gain stage. 2x P ch outputs. 2x N ch outputs.
V3: one dual gain stage. 4x P ch outputs. 4x N ch outputs.
EDIT: don't mind the marking error
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 11:05 AM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
Copyright ©1999-2017 diyAudio
