F5 Turbo Circuit Boards
Old 2nd June 2012, 08:35 PM   #1521
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Ok, I'll post the proposed final designs here because at some point corrections were made. Melon Head, would be very grateful if you'd look them over, then we can send them off to the PCB fab.
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 2nd June 2012, 09:02 PM   #1522
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Awful lot of potential current going through those psu board traces.
...Shape the sound , Man!
Old 3rd June 2012, 01:08 AM   #1523
Melon Head is offline Melon Head  Australia
Banned
First off, I was just referring to the template for the hole positions on the heatsing
This is exactly the way I like it. I have not checked the fine details but generally speaking, I like separating the front end pcb from the output, that way if people say "I want more mosfets at the output" you don't have to redesign a whole new pcb, you just design bigger output boards.
Ideally the front end should contain everything so that someone can go absolutely nuts with it.
First impression is very good.
I will check it against circuit diagram.
Old 3rd June 2012, 01:12 AM   #1524
diyAudio Editor
Variac's Avatar
We don't even have to design bigger output boards. Two output boards will bolt onto each heatsink on our big chassis and you can just daisy chain two boards together on each side to make a monster monoblock. If you want an n and p on each side for 2 channel that will bolt in place too.
The medium chassis only accommodates one board per side. Because it doesn't make sense to make a two channel F-5t in the medium chassis.
But again, you can put a "p" on one side and and "n" on the other to make a monoblock F-5t
Check the Universal Mounting specification in the Store here:
http://www.diyaudio.com/store/boards.html
And you'll see that the diodes just bolt on too..
Old 3rd June 2012, 01:22 AM   #1525
a.wayne is offline a.wayne  United States
Sin Bin
^^^^ ETA on Boards... ?
He, he, hee , I will let you know for sure on this, current is my friend ...
Old 3rd June 2012, 02:04 AM   #1526
diyAudio Editor
Variac's Avatar
No one's given the
I'll send them out as soon as we have a couple people trace them out and make sure that they're A-OK. Takes about 3 weeks for production.
Old 3rd June 2012, 02:11 AM   #1527
Banned
Yes, I noticed that. Very well thought out.
I also like that you have put N and P channel on separate boards.
It would be nice if you were to also do this for BA2 output. Or you could make these output boards compatible for both F5T and BA2, and just populate the relevant components. It would also reduce manufacturing costs.
Old 3rd June 2012, 02:30 AM   #1528
Banned
Which schematic should I refer to, to check the board?
Old 3rd June 2012, 02:34 AM   #1529
Banned
This is lookin good so far
Old 3rd June 2012, 03:12 AM   #1530
Rush is offline Rush  United States
Default Speaker output connection
I don't see where you connect the speaker wire. You supposed to double up the O/P connectors on the input boards?
Rush
F5 Turbo Circuit BoardsHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
