F5 Turbo Circuit Boards - Page 151 - diyAudio
Old 30th May 2012, 03:32 AM   #1501
noSmoking's Avatar
Originally Posted by jdkJake View Post
If you are using two separate transformers, I would fuse each separately.
A 6.5A fuse is not uncommon. Even at 5x20mm.
That's about where it should be around 10% of mains ,do fuse each transformer as it is a circuit too, That's how I got my nick name smoking stuff,lol I use circuit breakers and fuses, I had a SWTP Tiger.01 built 2 of them ,they would turn on oscilate and blow fuses everyone in school laughed at my system blowing fuses ,BUT they did gather around to listen,lol.
Cheers!
Old 30th May 2012, 03:38 AM   #1502
noSmoking's Avatar
Cheers!
Old 30th May 2012, 09:11 AM   #1503
Originally Posted by rubofdagreen View Post
So 2 x 800va =1600 / 120vac = 13.33 amp fuse? Really? Seems awfully big.
A pair of 800VA transformer will suffer repeated and frequent nuisance blowing of close rated fuses.
Fuses rated to start a transformer would normally be about 3 times the value of close rated fuses.
800VA / 115Vac * 3 = 20.8A.
A T20A fuse would be expected to start a single 800VA toroid transformer without suffering nuisance blowing on start up, or later.
Adopt a soft start circuit and close rate the fusing for each transformer.
You should find that a T8A fuse will work reliably. You may find that a T6.3A works in the long term if you select appropriate values in the soft start circuit.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 30th May 2012, 01:36 PM   #1504
I am building 2- V3 Turbo's. After studying Mr. Pass's article on power supplies, (http://www.passdiy.com/pdf/powersupply.pdf). It seems you need about 1500va transformer per 100 watts. 2- 800va in parallel looked like the cheapest way to go. Anybody have any idea how hot the diodes are going to get? They going to need a big heat sink or are we just looking for thermal stability? I have all the parts in hand and Teabag has mailed the boards. Any timeline on the Matched outputs Buzzforb?
Old 30th May 2012, 02:00 PM   #1505
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
paralleling xformers only after Graetz bridges !
just in case .....
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 30th May 2012, 02:02 PM   #1506
Most ClassA power amplifiers draw sufficient continuous current through the rectifiers that the rectifiers dissipate considerable heat.
They generally need heatsinking.
Each diode drops ~700mV.
You can calculate the dissipation of each diode from it's duty cycle (usually 50%) and the current passing times that 700mV.
From there it is an easy stage to select a suitable heatsink.
regards Andrew T.
Old 30th May 2012, 02:11 PM   #1507
minimum 2X the powerdraw.
so minimum around 500VA pr ch for your V3
i'm going for 600VA pr monoblock. at +/42V rails and bias at around 2.4A
Old 30th May 2012, 02:14 PM   #1508
2times does not seem right.
Prior to F5 I saw pass recommendations varying from 6times to 10times maximum ClassA output power for the transformer in a ClassA amplifier.
The F5 is a 27W ClassA amplifier and the minimum transformer rating I have seen recommended was 180VA. That is a ratio of 6.7times.
That fits within the previous PASS recommendation range. The F5 is no different in this respect from other ClassA amplifiers.
Why should the F5t be any different?
regards Andrew T.
Old 30th May 2012, 02:21 PM   #1509
power draw. not output.
standar F5 has 64W dissipation pr ch +brigde. and a singel 300VA transformer.
aleph2 has 270W dissipotion +bridge. and use 600VA transformer.
it will not hurt to use a bigger one. i fond that 3 times power draw is a nice sice.
then the transformer stays cool.
Old 30th May 2012, 03:29 PM   #1510
Sorry, I was thinking about the ones on the circuit board that Mr. Nelson is using for/instead of source resistors. I have seen bridge rectifiers get very hot and definitely plan to heat sink those..
"If the stereo amplifier is rated 200 watts per channel pure Class A, it will
draw about 1000 watts all the time, meaning that about 3000 watts of
power transformer is called for, no less." Nelson Pass on Power supplies 2001.
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 11:05 AM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
Copyright ©1999-2017 diyAudio
