Old 17th May 2012, 10:20 PM   #1491
buzzforb's Avatar
Any sort of entry hole or slot will allow for air movement through the case. Trying to direct that air movement is possible, but difficult. Too many holes, and the fan may have trouble pressurizing the case and there will not be as much air flow as a result. Velocity may be the more appropriate word instead of flow on the last bit.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 18th May 2012, 12:35 AM   #1492
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
So difficult compared to the fan blowing air at the fins, I'll agree! Velocity would be minimal, depending on the fan capacity, but much better than the air rising based on heat alone. I'm losing enthusiasm, but I should rig up an experiment...
Old 18th May 2012, 10:15 AM   #1493
Originally Posted by SRMcGee View Post
I'm not well educated in the heat abatement requirements of Class A amps but am planning on building a couple of F5 Turbo V3 amps
Build a standard F5 first.
Find out about the heat requirements.
Then use that knowledge to decide if an F5T V3 is manageable.
Old 18th May 2012, 10:40 AM   #1494
Will heat pipe be helpful in class-A thermal management? it seems that the effeciency of heatsink become lower with increment of it's size..
www.siliconray.com High Quality Audio Enclosures, Amp Kits, Amplifiers, PCB Fab Services
Chat with me
Old 23rd May 2012, 06:28 PM   #1495
I saw that someone had mentioned using a 2.5A fuse. What determines the size of fuse we should use. I did not see anything about it in the white paper.
Old 23rd May 2012, 07:03 PM   #1496
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
VA of xformer , C bank ,what sort of soft start , you are using ?
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 23rd May 2012, 07:25 PM   #1497
noSmoking's Avatar
Default fuse sizes
hi,
I keep seeing folks post about what fuse to use ,Here's my 2cents form 40 years of building,
The ac side of the transformer is one circuit be it 120 or 220 volts ac,it needs a fuse in this circuit.
The DC side if it's a single voltage it needs ONE fuse to cover the whole load.
If the DC side is using 2 DC outputs you need 2 fuses one for the positive side and one for the negative, each one half the whole load,
Now here comes the figuring each fuse must at least cover it's load ,ohm's law will give you a idea of load current, and then the amount over what is required is your insurance I have seen 25% or more and a slo-blow is x2 it's normal requirement,but in the dc side a fast fuse is best and rated about 10% above what is required,
I have had many amps that oscillate blow the fuse, not the outputs so I use them,For my personal F5 I use the cl60 thermistor and the fuses recommended by Mr.Pass,,,,,,anyone wants to pinch in on there recommended values Please do!!!!!!
Old 24th May 2012, 08:33 AM   #1498
Mains fuse = transformer VA / mains voltage
Old 29th May 2012, 11:37 PM   #1499
So 2 x 800va =1600 / 120vac = 13.33 amp fuse? Really? Seems awfully big.
Old 30th May 2012, 01:53 AM   #1500
jdkJake is offline jdkJake  United States
If you are using two separate transformers, I would fuse each separately.
A 6.5A fuse is not uncommon. Even at 5x20mm.
-- jk --
F5 Turbo is posted Nelson Pass Pass Labs 589 1st March 2013 01:19 AM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 18 24th January 2013 12:43 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
Copyright ©1999-2013 diyAudio
