F5 Turbo Circuit Boards - Page 149 - diyAudio
Old 15th May 2012, 12:07 AM   #1481
nrg2009 is offline nrg2009  United States
Great, what a nice collaborative effort across continents!! You realize how hard this is to do in business and we are doing it here! ;-)
Old 15th May 2012, 12:14 AM   #1482
Originally Posted by Variac View Post
We'll Shortly update Toecutter's spreadsheet and announce it here when you should go review the spreadsheet and confirm your interest.
Mark
so these aren't going to be available in the diyaudio store . just to some people that had signed up on a spreadsheet i've never seen ?
sorry just trying to understand .
cheers Woody
Old 15th May 2012, 12:31 AM   #1483
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
No, the spreadsheet is to gauge interest in different options. However it was started with the intent of it becoming an order form I think. Now, we'll decide on the options (the new design is more versatile IMHO so there will be less need for so many options.) and post the "winning" board options in the store where you can order them. All boards will come from the store. There was interest in hundreds of boards. Seems that it might be best to do a first run of about 100 or so to make sure the board is perfect. People willing to risk it will be able to sign up and pre-order at the store, and the boards will be sent out as soon as they arrive. The more cautious can then order from the second batch. That's the plan for now.
"The geek shall inherit the earth"
Burning Amp thread here on diyAudio [/B]
Old 15th May 2012, 01:39 AM   #1484
Variac, I'm a huge fan. I will try to make it to SF in October.
Old 16th May 2012, 07:39 AM   #1485
diyAudio Editor
Variac's Avatar
Ok for that kind remark, here's exclusive news that hasn't been announced yet anywhere, with a Netherlands angle:
Bruno Putzeys the Class D guru at Hypex, will give a presentation at Burning amp!
Old 17th May 2012, 07:56 PM   #1486
SRMcGee is offline SRMcGee  United States
SRMcGee's Avatar
Folks:
I'm not well educated in the heat abatement requirements of Class A amps but am planning on building a couple of F5 Turbo V3 amps -- one will likely be a stereo amp (in the HiFi2000 5U/400mm chassis) and the other a set of monoblocks (probably in two of the same enclosure). Given my lack of experience, I'm disinclined to stretch the outside of the envelope any more than necessary. As a result, I've reconsidered my opposition to forced air cooling in the stereo F5 Turbo amp and am thinking about using a single 80mm super quiet fan operating at low speed. The top and bottom panels on the chassis are expected to either have HiFi2000's standard venting (4 rows) or, if it is readily available, the 6 vented row option.
My question: is it reasonable to assume that such a fan, mounted squarely in the center of the rear panel, would facilitate even cooling throughout the interior of the chassis or is it likely that there will be "hot spots" where the air circulates and cools less. If the latter, would you expect any unevenness in the cooling to adversely affect the MOSFETs' operation?
Your feedback is appreciated.
Scott
Good decisions are derived from experience; experience is derived from bad decisions.
also, "Love + Time - Distance = Hate" (Louis C.K., 2017)
Old 17th May 2012, 08:48 PM   #1487
Awesome!! I can't wait!
Old 17th May 2012, 08:55 PM   #1488
a.wayne is offline a.wayne  United States
Sin Bin
Yes, We're working with UKToecutter. So far his boards fit the Universal Mounting Standard. Now he's debugging them. Since the general concept has been/is being tested
he is quite confident they'll be right. We'll Shortly update Toecutter's spreadsheet and announce it here when you should go review the spreadsheet and confirm your interest.
Mark
Great Mark , Toe cutter, Timeline .....?
Old 17th May 2012, 09:16 PM   #1489
buzzforb's Avatar
Originally Posted by SRMcGee View Post
Folks:
Scott
any fan based air movement inside the case or across the heat-sink will work wonders for your temperature level.
...Shape the sound , Man!
Old 17th May 2012, 09:52 PM   #1490
diyAudio Editor
Variac's Avatar
I've never tried this, but I've always been tempted to drill holes between each fin of the heatsinks through the base plate into the interior of the amp. Then have a fan mounted in the top inside of the cover with no other opening, oriented to pressurize the internal space creating a plenum. The air would exit between the fins "scrubbing" off the hot air next to the fin surface. If the fan fails, or has a thermal switch cutting in and out as needed, the fan hole would vent internal air.
I cleverly have a friend with a milling machine, which would make it a lot easier than drilling like 150 holes so will probably give it a try.
Easiest way would be to mill grooves through the backplate side to side from the inside. Opposite the direction of the fins. But they would have to be staggered or something because a long side to side slot would stop heat from spreading through the heatsink base
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 11:05 AM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
Copyright ©1999-2017 diyAudio
