F5 Turbo Circuit Boards
Old 7th May 2012, 11:27 AM   #1421
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Originally Posted by jacco vermeulen View Post
Hola,
at 15A, homes.
For a higher Vf at 0.1A, see the OnSemi MUR3040/60 PTG, not as linear though.
(hope you gents realise that a diode is a semiconductor)
Meaning it will add its on nonlinear characterstics, correct?
...Shape the sound , Man!
Old 7th May 2012, 11:47 AM   #1422
AudioSan is offline AudioSan  Norway
Originally Posted by audiok View Post
Is anyone finish F5X ? Can you share the comment , compare with normal F5 ?
Thanks.
this is F5 Turbo thread. not F5X
Old 7th May 2012, 11:50 AM   #1423
R.I.P.
If you are using k170/j74 from the lower end of the bl grade be careful that the bias does not exceed the Idss.
No one suggests that the bias of a jFET should exceed the Idss.
Some experts have said and repeated the message that operation (implying AC duty cycle) can take them into the Idpk>Idss area.
regards Andrew T.
Old 7th May 2012, 12:23 PM   #1424
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 7th May 2012, 12:26 PM   #1425
R.I.P.
Is "??" asking for more explanation, or is it directed to another post?
regards Andrew T.
Old 7th May 2012, 12:37 PM   #1426
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Originally Posted by buzzforb View Post
I would agree and i think this agrres with the numbers you are getting from the original article. I have even considered J309/271 in the cascode version.
Did you try your alternative N-Channels FETs from Fairchild on the board?
Salas Boards 2018 GB Open Click Here to Sign Up! Ends 5/27/18 | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 7th May 2012, 12:48 PM   #1427
buzzforb's Avatar
Yes, I am going to have transfer curves of the FQA16n25C vs FQA19n20C in next day or so. I am also going to include the FQP 19n20C in the mix. I have had both FQP and FQN versions on the board, and both have functioned perfectly. The F5/F5T is a REALLY easy build and a great project for first timers IMO. I will be playing music through both channels tonight with bias at 400mV. If all is ok, I am going to hotbox them and see if that changes anything, heeding Jacco's wisdom of real life amp temps. I
Old 7th May 2012, 02:00 PM   #1428
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Meaning
that numbers on a datasheet are average numbers.
I measure voltage drop on LEDs, zeners and diodes. Matching MOSFETs to 10mV Vgs spread, then hooking it up to a random pick diode bit strange imo, better safe than sorry.
(i compensate lack of wisdom, by thinking up excuses for still having close to 1k in power diode duallies burried in the back yard)
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 7th May 2012, 02:39 PM   #1429
buzzforb's Avatar
Understood. Thanks for adding another step
Old 8th May 2012, 12:37 AM   #1430
buzzforb's Avatar
So i have some disappointing news. I hooked up both versions of the F5T V3 to parallel set of these.
http://www.creativesound.ca/pdf/CSS-...ata-080909.pdf
2ohm and 86dB doesnt make for an efficient load, or so I thought. Both versions with just a single pair of output devices could easily make for an uncomfortable listetning session yet neither version even raised the heatsink temperatures. This reminded me of one of the really great assets of the F5, GRUNT. I am not sure i have enough of a difficult load to push these things. I cannot imagine what the 4 pair version is capable of. I guess i will have to hook both channels up and give a listen tomorrow. A little critique for the group Anybody got any big subwoofers they want to send my way. I guess i can try a pari of parallel ca22rnx's that i have. If that doesnt work, i could try powering my neighbors Prius. Enough screwing around, hope to have more info tomorrow. Interesting point, the freestanding diode version showed no signs of sweating.
F5 Turbo Circuit BoardsHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
