F5 Turbo Circuit Boards - Page 142 - diyAudio
Old 7th May 2012, 01:31 AM   #1411
buzzforb's Avatar
This is a very important error, Eyoung. The part spec'd by Nelson is the Mur3020W and is linked below
http://www.vishay.com/docs/94080/mur3020w.pdf
Very easy mistake to make. Fortunately anyone who got this part would not suffer any negative consequences, as it indeed conducts much later than the "w" designated part.
Tea is right about being able to tweak circuit for other idss fets, but doing so does change parameters such as FE gain. How much this affect things, I do not know. I dont thin it matters whether it is cascode version or not. Low idss fets should have same effect no matter the version.
...Shape the sound , Man!
Old 7th May 2012, 01:48 AM   #1412
eyoung is offline eyoung  United States
eyoung's Avatar
I got lazy and did not type the full designation I got those figures on the IR data sheet for the MUR3020WTPbF. I was wondering if there is a single diode substitute to make it easier to piggyback on a stock F5 V2.0 board, any suggestions?
E in the warm South
"Lead me not into temptation...I can find it myself."
Old 7th May 2012, 02:18 AM   #1413
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
So please look over UKToecutter's boards here and check for errors. Otherwise they're ready to go. He has decided to have the boards available in the store instead of sending them out himself.
Here is his spreadsheet for ordering boards.
https://docs.google.com/a/crozone.co...nN2xyeUE#gid=0
Problem is that the boards are a bit different now, but to me it seems easy to figure out what people want. These are the assumptions I made:
First categories are Input Boards and Balanced Input Boards. It would seem that they are now the same thing, ie now a double board with the scored center line?
So it seems we could combine the categories, and for each 2 old input boards requested put 1 new Input Bd. And for each balanced board requested 1 new Input Bd.
Next category is Output Boards.
the old Output Bds worked for both P and N channels. If someone ordered 2 then its pretty safe to assume that they wanted one N and one P? I note that all the orders are for an even number, so I think its safe to assume that they want half P and half N.
Hmmmm? Combo boards? And Single boards? Now that we have boards with only 2 positions, maybe we don't need singles? Maybe just cut the number in half , then make half P and half N?
I think we'll create a New Board Request spreadsheet. And leave the original, and ask you people to confirm that what you put on the NBR spreadsheet is correct, and that you're still interested. Its been a while so confirmation of interest is good..
We'll get to it soon
Mark
"The geek shall inherit the earth"
Burning Amp thread here on diyAudio
Old 7th May 2012, 02:37 AM   #1414
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by eyoung View Post
hola guys, correct me if I'm wrong, but the MUR3020 has a V forward of 1.05V@25c and .85V@150c.
Hola,
at 15A, homes.
For a higher Vf at 0.1A, see the OnSemi MUR3040/60 PTG, not as linear though.
(hope you gents realise that a diode is a semiconductor)
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 7th May 2012, 03:40 AM   #1415
Rush is offline Rush  United States
If we are looking down on the boards in the linked photo, as far as I can see Q5 and Q6 are still wrong. The double line is on the wrong side. The Emitter should point to the JFET's Drain and they don't. I had to draw them on a piece paper and turn it upside down to make sure.
I put them in according to the graphic on the board and had to unsolder them in the prototype V2 boards and turn them around.
Secondly there are not enough ground holes. The link hole has no open ground hole to link to. Input ground wire, power ground wire, Link to where? double wires in one hole?
One more thing, in this new version, where is the hole for the speaker output? All the O/P holes in the input board are full, you wouldn't want to take the speaker wire from the N or P boards. You should connect the speaker wire to where the N and P boards connect together, at the input board, right?.
Rush
Old 7th May 2012, 10:33 AM   #1416
Originally Posted by buzzforb View Post
...........they are not biased beyond their passing or they would take off,.......
What do you mean?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 7th May 2012, 10:34 AM   #1417
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
So we should be recommending 9-10ma matches based on our experiences is what I take out of it. Easier setting with the pots.
Someone is RUSHing me some JFETs up generously to see how they play in my F5T boards.
Salas Boards GB 2017#1 ON ORDER | GB 2017 #2 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards On ORDER
Old 7th May 2012, 11:15 AM   #1418
buzzforb's Avatar
Originally Posted by AndrewT View Post
What do you mean?
My bad. Mental fart. Lost sight of the fact that the fet still controls current throught the circuit.
Old 7th May 2012, 11:18 AM   #1419
buzzforb's Avatar
I would agree and i think this agrres with the numbers you are getting from the original article. I have even considered J309/271 in the cascode version.
Old 7th May 2012, 11:21 AM   #1420
audiok is offline audiok  Hong Kong
audiok's Avatar
Is anyone finish F5X ? Can you share the comment , compare with normal F5 ?
Thanks.
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 11:05 AM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
Copyright ©1999-2017 diyAudio
