Old 17th February 2012, 01:44 AM   #121
expert in tautology
bear's Avatar
Geez, my reading comprehension is down the tubes... heh.
You said not. Yikes.
nvm.
High slope transients are HF... that is the same as a high amplitude leading edge on a cannon, which has a LF component... annoying to think about. So just how much air should a tweeter move to result in a "realistic" reproduction? Heh.
_-_-bear
_-_-bear
http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
Old 17th February 2012, 11:54 AM   #122
Back home from working away.
I have done some more work on the layout and made it a bit more tidy.
Reading back through some posts during the last few days somebody was talking about possible alternatives for the MUR3020's in TO-220 packs.
Can I get confirmation if this is required and that the alternatives will be suitable for the F5. I should be able to provide for some alternate pads if needed.
Andy
Old 17th February 2012, 12:24 PM   #123
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Example : STTH2002C (in standard TO-220 dress)
On fire sale for 42 $cents each at DK
Not so much,.......if it says "ZM" in the corner.
Old 17th February 2012, 12:42 PM   #124
Looks reasonable but quite a bit slower than the MUR3020's.
Is that going to be an issue?
Old 17th February 2012, 01:25 PM   #125
Would you like the diodes to switch, or slide ?
Me regard the diodes as a torque converter in an automatic transmission, smooth gear change.
(slower ? really ?)
Old 17th February 2012, 03:12 PM   #126
Revised F5 v2/3 layout and PSU layout.
Very difficult to add TO-220 diode arrays without reducing track widths dramatically.
Old 17th February 2012, 03:42 PM   #127
Horio is offline Horio  United States
Newbie
Horio's Avatar
Looking great UKToecutter.
Maybe you were planning to do it at the end, but I don't see any mounting holes. I know the amp boards could probably be supported by the FET/Diode legs, but I'm a big fan of standoffs too.
Old 17th February 2012, 04:12 PM   #128
I was thinking that the amplifier boards would be supported by the FET's being bolted to the heatsinks (I could put some mounting holes if people would like them).
I was planning to put mounting holes on the PSU.
In fact, I'll put them on now.....
Old 17th February 2012, 04:20 PM   #129
lhquam is offline lhquam  United States
UKToecutter:
I really like your layout.
I do not understand many of the test-points. In particular why aren't there test-points for the measuring the bias current, ie. the voltage across the the source resistors? TP10 and TP5 appear to be connecteded to the same trace. Same with TP3 and TP9. What are TP1 and TP2? How are TP11 and TP8 used?
I do not understand why the (wide) traces from the diodes to the MOSFET source pins (and MOSFET side of the source resistors) need to be only on one side of the board. It might be better if the connection from the source-resistors to the MOSFET source pin was on both sides.
I am looking forward to using this board.
Old 17th February 2012, 04:29 PM   #130
bobodioulasso's Avatar
Input transistors including cascodes are very close to high output currents.
Might be an issue?
F5 Turbo is posted Nelson Pass Pass Labs 589 1st March 2013 01:19 AM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 18 24th January 2013 12:43 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
Copyright ©1999-2013 diyAudio
