F5 Turbo Circuit Boards
Old 31st March 2012, 09:57 PM   #1261
AudioSan is offline AudioSan  Norway
Originally Posted by a.wayne View Post
Voltage rating is too low , unless doing V1 ...
nope. works vell with v2.
v2 on 32V rails is just fine.
Old 31st March 2012, 10:09 PM   #1262
yes. let the build begin
Old 31st March 2012, 10:52 PM   #1263
arche13 is offline arche13  France
thank you Bobodioulasso
Old 31st March 2012, 11:32 PM   #1264
a.wayne is offline a.wayne  United States
Sin Bin
32v rails with 35v PSU caps ... Interesting ....!!!!
Is anyone doing V3 boards...?
Old 31st March 2012, 11:47 PM   #1265
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
UKToecutter and I have discussed how great it would be to have optimum spacing for MOSFETS and also work with the "diyAudio Standard" or "UMS" as well as be as versatile as possible for the various F-5 Turbos. For a board design to be carried in the store, it must fit the Standard, but I'm willing to add another 4 holes to the Standard for big chassis only. After all, they are bigger!
I've come up with an approach I think will work, for Mr Toe and the rest of you to comment on, and it only requires a couple more holes in the "Standard" I'm drawing up a diagram and will post it tonight probably.
Originally Posted by UKToecutter View Post
Bear, I created the 80mm spacing layout some time ago to try and match the UMS. It doesn't match the UMS actually anyway but I had it on my PC already so I tweaked it a bit with your suggestions.
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 31st March 2012, 11:47 PM   #1266
Rush is offline Rush  United States
I bought a 25 volt AC dual secondary, 1000 VA transformer, should deliver 32 volts DC under load. 35 volt caps will be fine.
Rush
Old 1st April 2012, 12:56 AM   #1267
whats stange about that? its 10% under limit.
Old 1st April 2012, 12:57 AM   #1268
Rush
that will be just fine
Old 1st April 2012, 04:25 AM   #1269
Default Stuffed resistors on one board
First off the board quality is good.
First and second photos are stuffed not soldered. Third and forth photos are soldered.
First thing, R3 and R4 we changed from 1/4 watt to 2 watt and the larger leads don't fit in the holes, 1/4 watters do. I drilled them and all is good.
Second thing the middle input terminal block can't be used, the resistors are in the way of the openings for the wires. Have to solder directly instead of the block.
As Bear had pointed out it is very congested in the middle of the board, but certainly workable except for the terminal block location.
I put a few test points in just to see how they looked, need to finish the large resistors and transistors next. Then layout the outputs on the heatsink, drill & tap, the hard part!
Going to quit for the night. Not sure when I can get back to this, hopefully soon.
Rush
Old 1st April 2012, 04:36 AM   #1270
just drop the block for input. you are better of soldering it anyway
F5 Turbo Circuit BoardsHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
