F5 Turbo Circuit Boards - Page 125 - diyAudio
Old 30th March 2012, 12:04 AM   #1241
Banned
Originally Posted by Bksabath View Post
Capacitor board
Just need rectifiers bit and your faw cap choice
Left it big for duble caps diameters.
who said one picture is worth 1000 words?
No not selling, just free ideas from SAS
(Spagetti Avoidance Society)
cook your own board like one on this post
Plenty big straigt tracks any caps size you like all is needed is new set of holes.
and the rectifier bit but as there are so many different tipes to be had I did no bother with it
Old 30th March 2012, 12:10 AM   #1242
Originally Posted by Daniel(Del) View Post
These won't fit - 35mm
so it is for F5turbo and F5turbo PSU. then drop the voltages down just a bit.
Old 30th March 2012, 04:52 AM   #1243
Banned
On capacitors
From data sheet quote:
The specifications listed at right shall be met when the
capacitors are restored to 20°C after D.C. bias plus
rated ripple current is applied for 3000 hours at 105°C,
the peak voltage shall not exceed the rated voltage.
This apply for the capacitors in post 1217.
One is never going to get more than 105C inside the amplifier for more than 3000 hour continuosly so no problem there
Rule one do not get abowe rated voltagge
Rule 2 fit the best compromise with quality and cost that you can as long as you got the space for it.
If you got no space for it you can alwaise create same more (build bigher box )
some one even uses 2 boxes one for suply one for Amp or 3
Rule 3 if the board does not fit design is wrong
Rule 4 read the data sheet.
Rule 5 do waste time posting as it will get trown back to you
Ops keep forghetting rule 5 I bett
here is data sheet
http://uk.mouser.com/ProductDetail/N...EanQTk4FLlg%3d
Old 30th March 2012, 06:59 AM   #1244
I will relay the boards to accommodate 35mm for the second batch
Old 30th March 2012, 08:03 AM   #1245
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by labjr View Post
Panasonic caps are probably rated a bit conservatively. Nelson goes close to the rated voltage in the F5.
You're forgetting that 24V or 49V rails makes a difference.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 30th March 2012, 03:12 PM   #1246
That's very nice. Thank you!
Old 31st March 2012, 02:49 PM   #1247
arche13 is offline arche13  France
Somebody can he(it) help me which plan of the version f5 turbo for 100w 8 ohm, I bought caps 15000µf for supply, for the part rectifier is one obliged to put diodes MUR, where we can put simple bridge 35A. Thanks to all for your answers
Old 31st March 2012, 02:59 PM   #1248
you can use bridgeif you like. the diodes can be bypassed.
like i did here.
Old 31st March 2012, 03:31 PM   #1249
oiphy is offline oiphy  Norway
diy newbie
oiphy's Avatar
arche13 you would want the v3 version.
" If you're going throu hell, keep going"
Old 31st March 2012, 04:03 PM   #1250
Thank you
AudioSan and oiphy
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 11:05 AM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
Copyright ©1999-2017 diyAudio
