#1111 |
Without direct access to a surface grinder, there's the option of stopping by at an engine head reconditioning shop (if desired), shouldn't cost an arm and a leg (or a child's foot for some).
Or go for BS' hand lapping routine. (mirror, mirror, on the wall)
Not so much,.......if it says "ZM" in the corner. Last edited by jacco vermeulen; 21st March 2012 at 11:56 PM. |
#1112 | |
![]() around here they'r not on every corner
aleph P1.7 pre. F5 power amp. CDpro2(need DAC). Vivaldi8 speakers |
#1113 | |
#1114 |
Hi Jacco
Maybe you can explain properly why precision ground surfaces stick togheter. Hand lapping does better Use to do that at 12 helping out Franciscan Monk hand lapping telescope lenses. And valve seats on marine diesels after that. And another thing I was going to make heat sink out of cooper but not enough scrap to make it possible in the UK Cooper roofs are not that popular here but if there is a Cooper roof near you it means you can get the proper scrap Silver braze he thin Cooper sheet to the thick base (afer you cuntersunk the bolt heads naturaly) and use a litle fan. Easier than to weld Aluminium for me. litle fan is must have for Cooper sinks (remember radiated heat is poor for mirrors) Proper F5 turbo sinks material in Cooper is about £500 if one can not get scrap. |
#1115 | |
#1116 |
Why one would go to buy stuff from Ebay for then having to replace parts.When even me with a few tips from intraweb can design its on thing. And spend a few hours building things. What pride one has at putting togheter IKEA like bits apart from telling its mates I have built this and did not even have to read the instruction manual ![]() Maybe I shuld start selling stuff on Ebay insted of giving away info for free. Only joking by the way so dont get oll titty lippy. On a more serious note how would you like to buy my soft start I use 20 A rated relays? And you know where to slag me off if things go wrong? Ihquam that is most definitley a wery good link You Lot certanly know that I am not that clever so you beter read ESP page I certanly did Last edited by Bksabath; 22nd March 2012 at 12:17 AM. |
#1117 |
Hand lapping two bit of metal produces a finished surface (lots of care needed) that has very few 'peaks and valleys' - if you pull all the scratches out, your left with a surface which will expel air causing a vacume effect.........
#1118 |
and engine heads should not be ground this way as there will be an easy path for the fluids/gasses to flow through.......
realy realy basic eng. theory Like the boards Toecutter, well done |
#1119 |
It can probably be modified to do what you need. The relays look like some made by Omron I've seen in appliances. I think they are universal standard sized, but not positive. Hard to beat for the money though.
#1120 | |
Copper is pretty pricey, better to save the money , fets are cheaper to buy if you let the smoke out, take the cash and buy copper options .. Big sinks, 10 -15 mm heat spreader , if that's not enuff ... Tits up ....
| F5 Turbo is posted | Nelson Pass | Pass Labs | 589 | 1st March 2013 01:19 AM |
| F5 clone boards (inc PSU boards) | Tazzz | Swap Meet | 18 | 24th January 2013 12:43 AM |
| F5 turbo problems | Rob Dingen | Pass Labs | 17 | 11th January 2013 08:38 PM |
| F5 Turbo ............. if only !!!!!! | a.wayne | Pass Labs | 23 | 21st January 2012 02:24 AM |
| UGS Boards and F5 boards | DUC985 | Swap Meet | 0 | 7th January 2009 07:21 PM |
