#101 |
IF YOU ARE LISTENING ON THE EDGE, MAYBE YOU NEED DIODES...
THE EARS HAVE IT . WE NEED SOME AUDITORY RESPONSE.... LISTENING IN THE BACK ROW....EL
"Sometimes obstacles are put in our way to make us slow down so that we can enjoy the journey and appreciate the destination when we eventually get there" |
#102 |
So what no diodes now ...? ...
#103 |
expert in tautology
My only perhaps useful comment is to make the pads for the small stuff as BIG as possible, especially if there is the potential for having to take parts in and out.
Also make the traces on the small stuff NOT as thin as possible, actually make them as thick as reasonably possible. The trend is to make these boards with thinny thin thin thinny traces because you see it in commercial PCBs where they try to slide traces inbetween things like IC pins. Bad idea for audio, imo. Imo, FAT traces and BIG pads are good. traces as wide as the pad are fine. ( I prefer a jumper or two over thinny traces ) On the pads, alternately make them oblong rather than just a single pad diameter... hard to illustrate in ascii, but, single pad = o oblong pad = ooo hope that illustrates the idea... YMMV. _-_-bear
_-_-bear http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
#104 |
Don't gold plate the copper -- I've fixed F5's and F4's for folks who've had bad solder joints on gold-plated boards.
#105 |
expert in tautology
Really?
Hmmm... seems unusual Jack. What solder was used? I get good wetting on all the gold I have ever soldered, afaik. Curious. _-_-bear
#106 |
What is it with some of you guys and this "gold plated is sooo much better" mentality?
Gold is inferior in conductivity to both copper and silver. Gold rules in corrosion resistance, in harsh environments, and is very well suited for "finger type" and clamp-down type connectors where the gold surface is one of the two contact points. Otherwise gold sucks, and is not a very solderable surface. Soldered gold pads are usually avoided in high-tech instrumentation.
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals! |
#107 | |
Absolutley agree with you As evvery time I try to post same definitive numbers I get flied and give a chance to cumpolsory poster to fell superior I was asking questions insted. There are to many factors involved for straight answer One need to consider Normall max listening volume (Search for Pano tread to get Idea) Impedence of speakers (normaly much worst than rated especialy at low frequency where signall normaly present maxymum energy demand) Those will be values that aply only to each individual case In my case I have Polk LS15i nominal 4 homs in my smalish room 87dB is fine after Pano test I will rarely ask the F5 to give me more than 12 rms out The music I listen to is mostly not Classical so dinamic range is not big issue. I am quite happy with 35 volts rails and Bias of 2.5 A on each rail Yess at time the amplifier will go in to class B but I do not think I will be able to distinguish the difference at such level I still have the option of going balanced for 3dB more head room (Ops there it cames) This will be different from one having 40 V pluss rails when diodes became needed maybe Or someone with home made super duper speakers with 90 + dB efficency and impedance curve that gos down to fraction of homs. |
#108 |
The difficulties with gold are ussually the type of plating that is done. There is electrolisis gold and some other palting method(Brain Fart). Personally, I agree with some posters that gold plated PCBs are extra raz-ma-taz that does not improve anything except the vendors pocket! Solderability sucks! (especially electrolsis gold) and it grows wiskers(just pretend your a space satalite) etc.etc.
The most important factor in PCB construction for our audio circuits, other than layout related crosstalk issues, is low DCR and inductance along with the ability to cary away unwanted heat from components! That boils down to wide, 2 3 or 4oz. copper! And, good vias! just my 2cents
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss |
#109 |
Being that this is the "Turbo" version, my vote would be 4 layer/4oz copper, and big fat power traces. I like my boards robust!......my 4cents
#110 | |
| F5 Turbo is posted | Nelson Pass | Pass Labs | 589 | 1st March 2013 01:19 AM |
| F5 clone boards (inc PSU boards) | Tazzz | Swap Meet | 18 | 24th January 2013 12:43 AM |
| F5 turbo problems | Rob Dingen | Pass Labs | 17 | 11th January 2013 08:38 PM |
| F5 Turbo ............. if only !!!!!! | a.wayne | Pass Labs | 23 | 21st January 2012 02:24 AM |
| UGS Boards and F5 boards | DUC985 | Swap Meet | 0 | 7th January 2009 07:21 PM |
