F5 Turbo Circuit Boards
Old 21st March 2012, 12:01 PM   #1051
UKToecutter is offline UKToecutter  United Kingdom
oh....
OK. Gimme 5 minutes to find my camera...
Old 21st March 2012, 12:07 PM   #1052
Daniel(Del) is offline Daniel(Del)  Brazil
hehe
Old 21st March 2012, 12:34 PM   #1053
OK,
Here they are.
PSU Board
SE Input Board
Balanced input board
Single Output Board
F5 V2 Combo Board
V2/V3 Output Board
Old 21st March 2012, 12:36 PM   #1054
1 sec. Photos will be back in a mo
Changed the photos as there was too much flash glare.
I had to take the boards outside into the garden to photo without flash.
Old 21st March 2012, 12:39 PM   #1055
Guys... What do you think about using the case of this amplifier to build F5T?
It was an amp made around 20 years ago.
It's original specs (don't know how true they were, perhaps a little too pretencious given 950VA power consume on max. signal):
200W RMS @ 8 Ohm
325W RMS @ 4 Ohm
The case dimensions are:
420 x 185 x 430 mm (WxHxD)
PS: The fins are bigger then they appear on the photos. I'm going to measure them myself and post them here.
More photos/specs:
AUDIORAMA - Equipamentos de Audio - NASHVILLE A77is
AUDIORAMA - Equipamentos de Audio - NASHVILLE Amplificador
Thanks!
Old 21st March 2012, 01:14 PM   #1056
6L6 is offline 6L6  United States
6L6's Avatar
Daniel - That chassis look like it could handle a F5v2 easily. I like it.
Toecutter - Wow! Wonderful!! Thanks for posting the photos!!!!
Old 21st March 2012, 01:24 PM   #1057
Really beautiful!
Old 21st March 2012, 01:33 PM   #1058
a.wayne is offline a.wayne  United States
Sin Bin
Sweet ......
Old 21st March 2012, 01:35 PM   #1059
It seems I won't be able to use the diodes, right? There won't be enough room to place the two output boards on top of the other with the diodes, because of the case height, and the depth is not enough for allowing them side by side.
Old 21st March 2012, 01:42 PM   #1060
You could build a V2......
F5 Turbo Circuit BoardsHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 07:02 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
UGS Boards and F5 boards DUC985 Swap Meet 0 7th January 2009 07:21 PM
