#1021 | |
I wonder if you'd consider adding a couple of columns for me. +- rail voltage and maximum output power. I think alot of builders would find it very useful (I certainly would). Regards Andy |
#1022 |
There seems to be a fundamental disagreement on the voltage drop from the +-V supply rails to the maximum voltage peak delivered to a resistive test load.
A table of supply rail to max power cannot be done until that disagreement is removed. |
#1023 |
Andrew,
Ok, no problem. I guess that can wait for the test builds. Andy |
#1024 |
The Panasonic ECG resistors can take a lot of punishment -- but they do like to be off the PCB a bit so air can circulate.
#1025 |
expert in tautology
For best sonics, imo, oversize ALL resistors.
My rule of thumb is to run them at <50% rating. _-_-bear
_-_-bear http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
#1026 |
Sounds reasonable bear ........
#1027 |
#1028 |
expert in tautology
me? reasonable?
Ha! I also like fat traces and big pads... space on the board (if possible)... _-_-bear
#1029 |
#1030 |
| F5 Turbo is posted | Nelson Pass | Pass Labs | 589 | 1st March 2013 01:19 AM |
| F5 clone boards (inc PSU boards) | Tazzz | Swap Meet | 18 | 24th January 2013 12:43 AM |
| F5 turbo problems | Rob Dingen | Pass Labs | 17 | 11th January 2013 08:38 PM |
| F5 Turbo ............. if only !!!!!! | a.wayne | Pass Labs | 23 | 21st January 2012 02:24 AM |
| UGS Boards and F5 boards | DUC985 | Swap Meet | 0 | 7th January 2009 07:21 PM |
