#1001 | |
I am out of my comfort zone making the next statement, but with V3 higher output power, all the feedback resistors should be looked at for more dissipation and maybe even higher wattage for R3 & R4 at some point. Rush |
#1002 |
Yes,
I've spec'd a 2W in the BOM's. Mouser have a 2W that'll fit, DigiKey part will need to be tombstoned. I'll increase the pad spacing for the second board batch. Andy |
#1003 |
110 Ohm !
Not so much,.......if it says "ZM" in the corner. |
#1004 |
changing the upper leg of the NFB from 100//100 to 220//220 reduces the proportion of the power delivered to the lower leg of the NFB.
Do the sums. eg Max V Output ~ 40Vpk (100W into 8r0 or 200W into 4r0 per half channel). total voltage across 10r + 220//220 = 40Vpk Ipk ~333mApk 10r resistor instantaneous peak dissipation ~ .333^2 * 10r = 1.1Wpk 2W resistors would do, but I would go a bit higher. try 3W to 5W 220r resistor instantaneous peak dissipation ~.333/2^2 * 220r = 6W. This parallel pair would need to be mighty for a +-45Vdc turbo. |
#1005 |
Interesting a 5 watter .....
#1006 |
Being a sinus, i think it's average power that counts into a resistor, not peak.
Or for square waves full blast measurement only. Last edited by bobodioulasso; 11th March 2012 at 06:02 PM. |
#1007 | |
instantaneous peak power will determine the maximum slope (slew rate) of temperature change in the resistor element (equivalent to change in junction temperature).
Since all normal Audio resistors have a non zero tempco, then the flatter the slope of the temperature then the better for the audio we are trying to pass. Taken to the other extreme. Pass A constant DC current through the resistors. The slew rate of the temperature change is zero. Yes the resistor is at an elevated temperature but the resistance does not vary. That is the ideal that we are trying to achieve. a quick reminder: that example was for a 100W into 8r0 "half" turbo. That is a very big and powerful amplifier. Quote:
#1008 |
#1009 |
Sorry,
what STO means? |
#1010 |
Short-Term-Overload.
equivalent energy = actual energy * (1+ Pd/Pr) Pd = Power dissipated Pr = Power rating
| F5 Turbo is posted | Nelson Pass | Pass Labs | 589 | 1st March 2013 01:19 AM |
| F5 clone boards (inc PSU boards) | Tazzz | Swap Meet | 18 | 24th January 2013 12:43 AM |
| F5 turbo problems | Rob Dingen | Pass Labs | 17 | 11th January 2013 08:38 PM |
| F5 Turbo ............. if only !!!!!! | a.wayne | Pass Labs | 23 | 21st January 2012 02:24 AM |
| UGS Boards and F5 boards | DUC985 | Swap Meet | 0 | 7th January 2009 07:21 PM |
