I understand I'm treading on shaky ground, but here goes.
Would there be any degradation in SQ if I replace the 47.5K input-load resistors with 100K or 150K resistors? I ask because each preamp channel will be driving two F4 channels plus a 67K-input channel of a subwoofer amp for a net of 17K-odd Ohms. That moves the filterpoint of the preamp's output-coupling cap to about 4.5Hz, about an octave higher than I'd like, and I prefer not to have to buy and install more expensive Teflon-film caps. Thx in advance. |
#2 |
The one and only
No degradation. Pick any value that amuses you. Probably 1Meg is OK.
#3 |
#4 |
#5 |
Probably I'll change them all to 100uF/50/std. pol. BlackGates bypassed with 1uF SoniCap Platinum (Teflon-film) caps.
But first, I'll listen (before improving parts) for as long as this compulsive tweakist can stand before turning on the soldering iron. ![]() --------------------------- From an e-mail exchange: Sure. If you like. They can be smaller, no problem. np ---------------------------- From: Jeffrey Behr Sent: Friday, February 10, 2012 5:06 PM To: 'Nelson Pass' Subject: FirstWatt F4--capacitors 1 and 2 I know you're a busy man, but perhaps you didn't see this, and I'd really appreciate your help: 1. Would it make sense to replace Cs 1 and 2 (in new-to-me, FW-manufactured-last-fall amps) with something like BlackGates? 2. Could they be any smaller…say 100uF or 150uF…and still work correctly? I have plenty of 100uF BGs so I could make them all (8 caps in 2 amps) 200uF caps. TYMV. Jeffrey Behr, Phoenix, AZ USA |
#6 |
#7 |
#8 |
Wowwa, cool, go for it dude!!!
But? That's all??? Hey, I don't suppose I'm hi-jacking if: I propose 1A minimum/Comp. FET Pair??? How about if we dump the Fairchild/IRF devices and go to 2SK1530/2SJ201??? Along with that, we should just put those Rs in the right area with .2-.22??? .1-.15 if you have balls(eggs-huevos, or matched FETs etc.)??? I suppose we need to work on that TL thingy for proper bias??? So do you want classA?// We'll Lower the 24V rails to 19-21V rails??? (a 15-0-15 0r 16-0-16 xfmr)... I just thought those would be improvements???
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss |
#9 |
Hm, I think I would leave it alone, as is.
Rather, I would build another one. But I only say this.
Those who would have deserved the life they are all dead already. "Oh, my dead dears!" - Captain Cat |
#10 |
possible improvement is to make it dual mono ( another toroid + another rectifier+filter block) ;
puttin' laterals instead of IRFP's will not gain much ( if anything) ; I made somewhere schm of biasing for lat's for someone I'll try to find it in my PC Arc edit - found it
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
| WTB firstwatt f4 clone | Ang | Swap Meet | 4 | 1st August 2010 09:57 PM |
| WTB FirstWatt F1 and F4 boards | toufu | Swap Meet | 1 | 11th August 2009 05:31 PM |
| FS pair F4 amp boards built | nvrgdenuf | Swap Meet | 2 | 16th December 2008 06:01 PM |
| F4 - Factory Built- First impressions | Manolo47 | Pass Labs | 9 | 2nd August 2008 05:53 PM |
| Improving on X-BosoZ to mate the F4 | steenoe | Pass Labs | 207 | 8th October 2007 12:45 PM |
| Page generated in 0.10197 seconds (79.72% PHP - 20.28% MySQL) with 11 queries |
