Old 9th February 2012, 02:14 AM   #81
Bigun is offline Bigun  Canada
Bigun's Avatar
wow, 100W Class A - that's huge !
nice to see the P3 harmonic adjustment - I used the same kind of thing (TGM goes tubey thread) before and can testify that it works but I expect it's much better with Class A than trying this in Class AB.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 9th February 2012, 04:52 AM   #82
ra7 is offline ra7  United States
Originally Posted by Bksabath View Post
I have FQP19N20 the TO220 version of the FQA
Current is nearer to the counterparts
They have been running since August and no problem so far.
They are still avvaliable evveriwhere.
How did you mount them to the heatsink? That TO-220 case looks weird. How many watts are they dissipating?
Old 9th February 2012, 05:38 AM   #83
This is too Cool !!!
After seeing some specs, I so want too build a set of these!!
It looks as if that they fill my requirements of at least 40Vpeak and into 1 ohm peaks as well for driving my DIY ESL's.
With a very simple circuit ,few parts and great specs to boot!
I already have a few large transformers in the 1000VA range that will work.
Just need to get the semi's and some very large capacitors and some sort of heatsink system,I have a liquid cooled type in mind maybe.
It will be awhile before I build a monster version but I will now start with the basic F5 though, as I was thinking about the AlephJ-X as well.
Thanks, Nelson Pass !!!
Jer
Old 9th February 2012, 07:11 AM   #84
sangram is offline sangram  India
Originally Posted by ClothEar View Post
For the JFETS, eBay seller "alweit" has well-matched pairs. Highly reccommended seller!
eBay - See alweit's JFETS here
Thanks.
Any idea if I can get the Fairchild output devices any more? I do have one set (unmatched) of the input pair but no output devices.
I assume with all the banter that any high-speed diode with a decent current reserve will do for the output stage.
Old 9th February 2012, 07:44 AM   #85
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
decent current , appropriate U/I characteristic (read -voltage sag at said current)
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 9th February 2012, 09:43 AM   #86
bifi is offline bifi  Germany
Default Fairchilds
Digikey and Mouser marked the Fairchilds as Discontinued / Obsolete
Old 9th February 2012, 09:48 AM   #87
^^Of course
Thanks so much!
Old 9th February 2012, 10:05 AM   #88
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
eBay seller has well-matched pairs.
1-2 % is "well" matched ?
Not so much,.......if it says "ZM" in the corner.
Old 9th February 2012, 10:17 AM   #89
EUVL is offline EUVL  Europe
Better than not matched at all, Jacco.
Patrick
xen-audio.com
Old 9th February 2012, 10:18 AM   #90
True, merely found the mentioned 2%, 1%, and 0.02mA amusing.
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
F5 Cascoded - an alternative for my interest in the Balanced F5 NYCOne Pass Labs 159 24th March 2011 05:23 AM
Turbo question Thawach Subwoofers 3 2nd March 2011 03:06 AM
E88CC turbo revintage Tubes / Valves 12 25th August 2010 11:52 AM
Zca ....turbo sakis Solid State 9 10th April 2010 04:49 PM
Copyright ©1999-2013 diyAudio
